09-05-2020, 08:39 PM | #1541 | |
If you drove your car with a bearing failure/knocking, it is likely that anything oil touched could be toast. You would potentially need heads/cams, oil pump, and all that to go into the used short lock. This will cost you much more than just buying a pull out. |
The Following User Says Thank You to ka-t_240 For This Useful Post: | gravitylover (09-06-2020) |
09-05-2020, 09:40 PM | #1542 | |
Drives: '13 Whiteout
The Following User Says Thank You to TommyW For This Useful Post: | gravitylover (09-06-2020) |
09-06-2020, 07:05 AM | #1543 |
I pretty much came to the same conclusion and have stopped looking at short blocks. I've found some nice looking reman, 0 mile long blocks but I'm not sure that's the best way to go either. It certainly isn't the easiest or least expensive. Thankfully I can be kind of patient with this so I can keep looking for a low mileage, used, complete motor. I have a line on one from a side impact wreck so we'll see how that goes. I had a mobile mechanic here at the house yesterday helping me put a band aid on my Durango so I can drive that for a few weeks and he quoted me 7 hours to pull the old motor and install the "new" one right in my driveway so I'm leaning in that direction.
09-06-2020, 11:09 AM | #1544 | |
09-07-2020, 10:06 AM | #1545 |
Yup, very common on the EJ motors for people "fixing" them to have no idea to replace their factory oil cooler after an engine failure, then have a second engine failure. Have seen it many times by shops/people that have 0 idea what they are doing.
09-12-2020, 09:26 AM | #1546 |
Is there a difference between manual and auto motors that would make install more challenging? I keep seeing them advertised as for manual or auto.
09-12-2020, 12:08 PM | #1547 |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
There is. If you’re doing a swap it’s ideal to get a same model year/transmission engine.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 Last edited by the new guy; 09-12-2020 at 01:50 PM. |
09-12-2020, 12:33 PM | #1548 |
I think I want to avoid 13's
09-22-2020, 11:34 AM | #1549 |
Drives: frs
The Following 2 Users Say Thank You to Teseo For This Useful Post: | gravitylover (09-22-2020), Ultramaroon (10-03-2020) |
09-22-2020, 01:42 PM | #1550 |
Those seem to cost a lot more than 14-16 motors, the difference is as much as $1k.
10-02-2020, 04:30 AM | #1551 |
Drives: 4wd zooks
I traded in my 2013 at a local dealer and a few weeks later it was sold to somebody else.
Somehow i still received another recall letter. It seems that everyone is avoiding the recall the recall! |
10-02-2020, 04:45 PM | #1552 |
Drives: '13 DGM BRZ Limited
Yeah, they call me about once every 2-3 weeks and send me an email a month to remind me to get the recall done. Just not going to do it. Not worth the risk at this point in time. Especially since my state doesn't require it for re-inspection.
The Following User Says Thank You to cnk For This Useful Post: | JesseG (10-23-2020) |
10-13-2020, 03:44 PM | #1553 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Had the recall done early May. Last week the engine began knocking as I headed to Yosemite. Got it towed yesterday and they will begin teardown Friday it sounds like. They have already agreed to cover repairs and a rental car if its due to excessive sealant. Will update next week hopefully
I was around 3500 miles post recall. |
The Following 5 Users Say Thank You to finch1750 For This Useful Post: | bcj (10-14-2020), Clipdat (10-22-2020), humfrz (10-13-2020), Tcoat (10-14-2020), Ultramaroon (10-14-2020) |
10-13-2020, 03:57 PM | #1554 | |
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Similar Threads | ||||
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
