Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-03-2019, 10:33 AM | #1 |
Drives: 2013 FR-s
Home brew front pipe
I swapped my stock front pipe with a resonated pipe. Now the car stutters a little when I pull away from a stand still. It just happens when I start off with a very light throttle.
I have the OFT 2 tune because I run a UEL header, I was hoping the OFT would learn about the cat delete and adjust, but its been 4 days now and its still stuttering. Would a leak cause it, I installed it myself. The borla muffler in this picture was swapped for a Vibrant 1792 resonator for clearance issues with the AT pan. |
12-03-2019, 12:31 PM | #2 |
Rust bucket enthusiast
if you have a leak pre-O2 sensor ( headers) then it could explain a poor running condition. At the front pipe I wouldn't expect it to cause any issue except additional sound and a stink
The Following User Says Thank You to DarkPira7e For This Useful Post: | HaXx (12-04-2019) |
12-03-2019, 01:44 PM | #3 |
Spun
Drives: 17' Focus RS
Maybe a longshot...but is it rubbing somewhere and causing ping or knock in the engine?
12-03-2019, 06:51 PM | #4 |
Drives: 2013 FR-s
12-04-2019, 09:48 AM | #5 |
Removing the secondary cat won't effect the ECU at all, the O2 sensors are both ahead of the front pipe (before and after the primary cat in the header).
Is it possible you're just trying to use less throttle because it's louder than before, and needing more throttle to pull smoothly?
12-04-2019, 10:10 AM | #6 | |
Drives: 2013 FR-s
The Following User Says Thank You to rmcelroy For This Useful Post: | ROFL it's Waffle (12-06-2019) |
12-04-2019, 12:37 PM | #7 |
Drives: jrsc_brz
catless front pipe makes the exhaust gasses smell? does the same go for catless headers?
12-04-2019, 01:37 PM | #8 |
Drives: 2013 FR-s
12-04-2019, 02:38 PM | #9 |
12-05-2019, 09:51 AM | #10 | ||
It's a total lack of cats that makes it stink. A catless front pipe with the stock header won't smell at all because there's still the stock cat in the header. A catless header with the stock front pipe won't either because there's still the stock cat in the front pipe.
The Following User Says Thank You to wparsons For This Useful Post: | HaXx (12-05-2019) |
Similar Threads | ||||
JDL 3" Over-Pipe/Front-Pipe Combo-Pipe SOLD | Jbelmonte | Engine, Exhaust, Bolt-Ons | 3 | 03-08-2018 09:00 PM |
WTT Invidia catless front pipe for a resonated/catted front pipe | nickmerronesucks | Want-To-Buy Requests | 3 | 05-10-2016 02:25 PM |
Gains from aftermarket catted front pipe vs stock front pipe? | Vmax911 | Engine, Exhaust, Transmission | 4 | 01-20-2014 01:42 PM |
Home brew trunk mod idea | JarredH | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-16-2013 02:43 PM |
Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
