Old 04-07-2013, 05:41 PM   #15
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Originally Posted by Spaceywilly View Post
The rest of the speakers are powered by internal amps in the head unit, like 99.99% of stock systems out there. Only the door speakers are powered by the external amp, the other dash speakers are also run off the head unit.
So let me gth this straight. The 2 door speakers are powered by the external amp.. The rear AND dash speakers are powered by the head unit?
TouchMyHonda is offline   Reply With Quote
Old 04-07-2013, 05:59 PM   #16
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Yeah. You can see for yourself. Reach under the trunk mat and unplug the amp, and you can hear all the treble coming from the dash and rear speakers.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 04-08-2013, 08:37 AM   #17
TouchMyHonda
Vtec Jesus
Wow that is so shitty. That little 198 watt amp runs just those two speakers and it sounds really weak.
Old 04-08-2013, 11:38 AM   #18
SkullWorks
Drives: SSM LT MT BRZ
...wait,
so now you are saying that even the FSM is wrong? the rears are also driven by headunit?
maybe it's the 2 drivers (door and dash) are driven by amp and the tweeters are driven by the HU. because this seems to show 4 speakers driven by the AMP (as referenced in my first post)
Old 04-08-2013, 11:41 AM   #19
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
STEREO COMPONENT AMPLIFIER is the amp in the trunk. F9 and E6 Front No. 1 Speaker Assembly are the front door speakers.
The Following User Says Thank You to Spaceywilly For This Useful Post:
SkullWorks (04-08-2013)
Old 04-08-2013, 04:18 PM   #20
SkullWorks
OK now I see,
H/U powers front stage (dash) and rear stage (tweeters in rear seats)
AMP ties into front stage signal wires for the door speakers...this is just so abnormal to my brain,
Why install an AMP to power 2 speakers in an 8 speaker car...
The Following User Says Thank You to SkullWorks For This Useful Post:
TouchMyHonda (04-09-2013)
Old 04-08-2013, 04:47 PM   #21
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
Originally Posted by SkullWorks View Post
OK now I see,
Yeah this is the first time I have seen it done this way. My guess is to make it compatible with different head units, since it could be either Scion or Subaru. The lower spec cars in Japan only come with the 2 door speakers, powered off the head unit (which is not included in Japan), with the option to upgrade to the 8 speaker system (what we have). If you had all 8 speakers powered off the head unit alone, the door speakers would be underpowered, so they added the external amp for the front speakers, and run it off the signal line so it works with whatever head unit is in there.
Old 04-09-2013, 12:57 AM   #22
MidnightRunner
MidnightRunner's Avatar
I went old school with the lc2i from audiocontrol. It's ok... But to be honest the cleansweep is the best thing out there nowadays, and it isnt that hard to install. There are a few threads on here that'll help you with wiring diagrams to know which wires you could steal a signal off of. Easiest thing might be to run your loc in the trunk off of the speaker signal that comes to the rear amp, and do your rca and full setup all back there. You could steal the remote off of the stock rear amp as well. I found a spot in the rear to sand and run my ground, so the only thing that you would need to run from the front is your power.
Deaden the doors, install some nice 2ohm 6.5s, replace the dash 4s and hpf with some 3.5s, and do a setup for an 8 in the rear and you'll be golden! You'll save money, and reap the benefits of your own labor
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 04-09-2013, 01:07 AM   #23
MidnightRunner
I would love to run a JL W8-7, I assume it would be far better than the OEM Audio plus subwoofer.
That sub will literally destroy your car. I wired a 12 mofo (the old mofo, not the sh!tty mofox) at 1ohm from my old thunderbird just for s&g, and everything in the car rattles. I thought the doors would fall off. The w7 is an absolute beast, so best thing is to stay away from that one. This car wasn't meant for thunderous bass, so my best advice is running an 8, or at most a 10 and calling it a day. I ran a pioneer 12 at 400w rms, and it's still way too much. My gain is non existent and the rear-view is unusable.
Old 04-09-2013, 01:12 AM   #24
TouchMyHonda
Vtec Jesus
What is the wattage the head unit is sending per channel?
Old 02-19-2014, 11:56 PM   #25
Darkrune
Darkrune's Avatar
Drives: 2017 86
over 9000
Darkrune is offline   Reply With Quote
Old 02-20-2014, 10:37 AM   #26
TouchMyHonda
Vtec Jesus
Originally Posted by Darkrune View Post
over 9000
The avatar explains it all like Clarissa.
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
Old 02-20-2014, 11:49 AM   #27
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Wonderbar View Post
$500-700 for a custom bass enclosure? I just built mine, a sealed and tuned box for about 30 bucks of Home Depot supplies.
For everything, line out converter, install kit, sub, amp, bass knob, box, I'm right at $500 bucks. Any decent aftermarket sub comes with specs to build a box which is tuned for that sub. A little research and you can tune the box for exactly how you want it.
I'm all for factory quality, but when it comes to audio, you can do aftermarket for cheaper and better.
A custom-made sub enclosure should run you only about $100-$400, actually. All-MDF on the low-end and a custom fiberglass enclosure on the high-end.
I have a 10W3v3-2, and it delivers plenty of thump, such that I needed amped aftermarket speakers to no be overwhelmed by the sub.
Once you start getting your own component items, kiss the OEM Audio system out the door. Those systems are specifically designed for the components they come with, NOT a mix and match of other items. Either go with a custom solution or the OEM Audio+ turn-key solution.
^GT5 Replay Photo Mode^
Alarm System on the Limited Smokinbuffalo BRZ First-Gen (2012+) -- General Topics 10 05-29-2015 10:17 PM
Focal sound system john_jre Electronics | Audio | NAV | Infotainment 5 08-22-2012 08:53 AM
The quality of the stock sound system?? Jruex22 Electronics | Audio | NAV | Infotainment 15 08-13-2012 04:59 AM
86 Sound System Skorov AUSTRALIA 25 05-09-2012 04:51 PM
standard sound system rating NESW20 Electronics | Audio | NAV | Infotainment 3 12-28-2011 06:29 AM
