Tracking / Autocross / HPDE / Drifting What these cars were built for! |
02-26-2021, 04:46 PM | #85 | |
Drives: 2017 toyota 86
Not saying what you said specifically is wrong by any means. Just taking what I said out of context. Yes, thank you for giving my day purpose and meaning. |
02-26-2021, 06:36 PM | #86 |
Drives: 2015 FRS
bro. When you race in a series that is governed by hp/wt ratio, torque becomes a real factor. It's not just about how much hp you have, it's also about using the torque you have on the few, slower corners that lead onto a straight to help give you valuable track position, so that once you are at speed in the 5000-8000 range your HP can really go to work for you. There are plenty of peaky power curves that got ditched last year for torque this year. So pretty dynos are great until you get on track and see what the car really does.
I don't expect anybody to understand that isn't racing in a highly competitive field where literally every little bit counts. I'm literally racing against detuned cars with the same peak power (or hp/wt ratio), but their dyno curve is flat from 5500-8500 all the way across with their peak HP. Or other cars with 180-200ft/lbs from 3000 RPM, so yeah, torque matters. My flat, relatively high torque curve (for a 2.0L) is a huge contributing factor to me being competitive. That's one thing this motor actually does right. That comment you cherry picked was specifically regarding the stupid carbon/aluminum driveshafts that are not applicable for race cars (which every racer knows) because the RPM's are too high and the car will vibrate itself to death. For stoplight heroes, or auto-x, it's fine, but not for anybody road racing that cares about their drivetrain. Regardless, as with all my posts, it's just to provide the community with more information, so they too can make informed decisions. Forums, for me, are a resource, and honestly nothing more. I don't post so people can praise me, or bust my balls. I do it so others can see what I've done and the information is out there for somebody else. I'll post up my further findings after the next dyno session. After that, I just need to put it on track and see how it really stacks up against my competitors because that's the real test.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos |
The Following 8 Users Say Thank You to prandelia For This Useful Post: | Capt Spaulding (03-01-2021), cjd (03-03-2021), Icecreamtruk (03-15-2021), Kiske (02-27-2021), NoHaveMSG (02-27-2021), RedReplicant (11-13-2021), RT-BRZ (02-26-2021), why? (02-27-2021) |
02-26-2021, 06:51 PM | #87 | |
Actually it was in regards to fluidampr. But statement still stands according to you yourself, you spend most of your time above 5k rpm where the 250 surpasses the 350, and would help to keep that torque flat even longer only complimenting what you’re reasoning for the JUN manifold was. Yes you’ll lose a little torque below 4500 rpm, But if you’re statement that you made still stands “the vast majority my RPM's are 5000-7500” then losing a small amount of torque below that range to gain/flatten/extend the torque in that range would be beneficial no? |
02-27-2021, 04:24 AM | #88 | |
Drives: '15 BRZ RA
02-27-2021, 08:07 AM | #89 | |
Drives: 2015 FRS
'15 FRS - GLTC spec
02-27-2021, 12:19 PM | #90 | |
Drives: Crapcan
Really curious to hear how that 4.556 gear works with your 8k redline. I'm too scared to spin my 13' engine that hard after ejecting some rocker arms into low earth orbit already.
02-27-2021, 12:44 PM | #91 |
I’d love to see you’re track data showing the frequency of being at 100% throttle below 5k rpm.
02-27-2021, 12:58 PM | #92 |
Drives: Crapcan
Not relevant to my point
03-08-2021, 10:25 PM | #93 |
Watching the C5 in this weekend's GLTC race, the Torque thing didn't really seem to lead to much of a gain coming out of the hole. But, I suppose that car is 3xxx lbs
11-11-2021, 12:07 AM | #94 |
Drives: '15 BRZ RA
Never saw any new dyno numbers. Is this engine still live with the 8000 rpm?
Similar Threads | ||||
Changing 2013 Intake Manifold to Red 2018 Aluminum Intake CARB Legal? | MJones_RB | Southern California | 7 | 11-09-2020 06:42 PM |
2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
FBM Intake Manifold | Fonzi | Engine, Exhaust, Bolt-Ons | 1 | 03-11-2016 07:36 PM |
Intake Manifold | Fonzi | Engine, Exhaust, Bolt-Ons | 0 | 03-03-2016 08:29 PM |
Intake manifold | viking | Engine, Exhaust, Transmission | 6 | 09-23-2014 11:08 PM |
