11-07-2020, 11:44 PM | #1583 |
Easily
11-08-2020, 09:56 AM | #1584 |
Thanks. Looks like I'm taking a ride to the Chicago area this week.
Hmm, what does it weigh? |
11-08-2020, 09:59 AM | #1585 |
Depends on how stripped down. Between about 350 and 380 pounds.
11-08-2020, 10:01 AM | #1586 |
Not too bad at all. I can make this happen. Hopefully be driving it again by the end of the month if this comes together.
The Following User Says Thank You to gravitylover For This Useful Post: | Ultramaroon (11-09-2020) |
11-17-2020, 06:33 AM | #1587 |
Drives: 2013 Toyota GT86
If Subaru/Toyota were a proper car manufacturer, the valve spring recall would include the complete timing kit and the VVT sprocket replacement.
In my country some cars are returning to Toyota due to high clearance on the valve shimmings because Toyota doesn't adjust the shimmings to the right spec after replacing the valve springs. The result is a high metallic noise like valve tapping. I guess the recall procedure doesn't include it, so they don't measure it |
12-04-2020, 04:19 PM | #1588 |
That last one didn't happen for a few reasons but one just popped up close to home that isn't hammered or unnecessarily expensive. I know there's a difference between manual and auto blocks, can I use a '16 (11/15 build) auto motor in my '13 manual car? What modifications need to be made?
12-05-2020, 12:54 PM | #1589 |
Answer took too long and the motor is already sold
I should know for the future though, can an auto motor be used easily in a manual car? It looks like the biggest issue is they use different oil pans and camshaft cover so are these parts interchangeable from my old motor? |
12-05-2020, 07:29 PM | #1590 |
Drives: FRS
What is the latest status on the valve spring recall?
Are people still doing it? Or did everyone who is gonna do it, already do it? I never did the recall. I doubt I will bother at this point. Who else decided to skip the recall ? |
12-05-2020, 08:24 PM | #1591 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | gravitylover (12-06-2020) |
12-06-2020, 04:59 AM | #1592 | |
If it ain't broke ........ |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | alxtheoreo (12-06-2020), Opie (12-08-2020) |
12-06-2020, 03:18 PM | #1593 | |
12-06-2020, 03:35 PM | #1594 |
義理チョコ
dat gloo doe
12-08-2020, 08:25 AM | #1595 | ||
Drives: '13 BRZ TLM Spec
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following 3 Users Say Thank You to Opie For This Useful Post: |
12-09-2020, 09:20 PM | #1596 |
Drives: '13 DGM BRZ Limited
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Similar Threads | ||||
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
