GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
08-14-2022, 01:41 AM | #15 | |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
My BMW X1 with the sport package came with 225/45/19 Bridgestone Potenza Summer tires. They are a stiff hard riding tire. We switched them out with Continental ExtremeContact DWS UHP All seasons for winter and they are noticeably WAY softer. |
08-14-2022, 05:09 AM | #16 |
Meow
Drives: GT86, Volvo 996
I bought my 1st gen 86 with Gramlights 57C6 in 18x7,5 with 225/40/18 PSSs (which looked amazing). Later switched back to the stock wheels & tires and definitely felt a difference in:
-noise level -harshness (per my GF - "it's less unpleasant when you need to pee") -agility and fun, but that's probably down to the lower grip tire I never put the gramlights back on. |
08-14-2022, 06:51 AM | #17 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
Just remember this from C&D. It is the BRZ 18 vs the GR86 17, but I assume those weights are the same for each car. I would of though compound and sidewall stiffness is that primary changes to the ride (all other things equal). |
08-14-2022, 02:11 PM | #18 |
Drives: Crapcan
Put 1 bar of air into a 1 liter container and 1 bar of air into a 2 liter container. Compress the sides of each container 25mm. Are they going to have the same pressure in the compressed state?
08-14-2022, 11:05 PM | #19 |
Drives: '23 BRZ Limited
Yep. More performance oriented you go, the stiffer and stiffer the sidewalls get to aid in performance and turn in.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
08-17-2022, 09:14 PM | #20 | |
There is probably some physics here about thickness of the wall, its own ability to compress, and the relative compressibility of a larger area of air vs a smaller one vs the amount you are trying to compress - but certainly 1 bar is still one bar pushing back on you - and the lower the pressure of the air inside, the more that pressure would define the overall effect - as things like the wall would be more relatively firm and therefore only come into the equation when the pressure needed to overcome the air pressure start to get high enough that there is also a difference in the compressibility of the wall. |
08-18-2022, 09:25 AM | #21 | |
Drives: GR86
Take the needle off, pull the plunger out as far as it will go. The seal the end with your thumb and push the plunger in as far as you can without breaking the seal. Repeat, but this time start with the plunger in the middle. The larger the starting volume the more compression it takes to equal the input force (assuming all other variables are constant). Of course applying this to tires/suspension means you're almost certainly changing at LEAST one other variable in every given experiment, which muddies the waters considerably. |
The Following User Says Thank You to Spektyr For This Useful Post: | NoHaveMSG (08-18-2022) |
08-18-2022, 09:44 AM | #22 | |
Drives: Crapcan
08-19-2022, 06:39 AM | #23 |
Weight Weenie
Drives: 15 FR-S
Tires being equal, more sidewall = more comfort. Less harshness over small bumps imo. More sidewall protects the rim too. I run 225/55 R16 on street.
See if you can get a ride in someone's car with decent 17's |
Similar Threads | ||||
Staggering 9" rear, 8" front handling experience? | wbradley | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 41 | 05-28-2018 01:54 AM |
Anybody attending "Ride Or Die Chicago 2014" Meet? | EggsAreGood | Great Lakes | 1 | 05-16-2014 11:16 PM |
Meet Tr!x5tuh's Ride "HERA" (slowly) | tr1x5tuh | Member's Car Journals | 20 | 02-05-2014 03:40 PM |
New C&D production BRZ review... "Porsche-like Handling" | Sport-Tech | BRZ First-Gen (2012+) -- General Topics | 112 | 04-29-2012 12:10 AM |
MotorTrend Blog: BRZ handling "better than Porsche, Godzilla and the McLaren" | Kimsey47 | BRZ First-Gen (2012+) -- General Topics | 59 | 04-23-2012 11:44 PM |
