Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
11-27-2020, 09:09 PM | #15 |
Drives: Subaru BRZ
Did this problem start when you replaced the looms and switches?
Sent from my SM-G973F using Tapatalk Last edited by Purist; 11-27-2020 at 10:11 PM. |
11-28-2020, 08:42 AM | #16 |
Drives: 2017 Toyota 86
Yes it did. When I first completed it all there were no lights at all on the switches. I did the different reset actions and now there are the flashing lights. I thought the windows would not go up before I did the reset but that could have been because I was always trying with the door open. The looms and plugs are all in perfect condition taken off a vehicle of same year, same transmission.
11-28-2020, 10:56 AM | #17 | |
Site Moderator
Drives: Stuff
Mine was due to a bad drivers side switch. No reset procedure would fix it. Since you already replaced the switch though then.. no clue. I would inspect your wiring work though, I'd assume the fault has to be there.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
11-28-2020, 07:07 PM | #18 | |
11-28-2020, 07:57 PM | #19 | |
Site Moderator
Drives: Stuff
So water in the switch might have killed mine.. I thought it was when it slammed between the door and rollbar (I absolutely hate the terrible hinges on these cars and the self-shutting doors).. but it then poured down rain at the same time. I'm not sure if it was the impact - or the rain.
-Dave
11-30-2020, 08:28 PM | #20 |
I checked the alps switch - drivers side and it has no water damage - looks great. I have been trying all day to work out with the wiring diagram (found on here) how this system works and I keep coming back to the ECU. I can just remove the purple wire from the connector that plugs into the window switch and that allows me to get out of the car and close the door without the window coming down and staying partly open but that is not a good long term solution. Is this something that can be programmed at the dealers do you think?
Similar Threads | ||||
Cant find passenger window wire from drivers side remote.. help? | luv85 | Electronics | Audio | NAV | Infotainment | 2 | 11-03-2020 09:13 AM |
Drivers side window glass | Akuma13 | Want-To-Buy Requests | 2 | 05-23-2017 12:25 AM |
Drivers window grabbing window seal and pushing it up. | stockysnail | Issues | Warranty | Recalls / TSB | 22 | 12-22-2015 01:08 PM |
Drivers window switch flashing - does nothing? | STS-V | Issues | Warranty | Recalls / TSB | 4 | 08-11-2014 08:42 AM |
Drivers Side Window (Not Seal) | Mister | Issues | Warranty | Recalls / TSB | 20 | 12-16-2013 02:56 PM |
