10-13-2020, 09:02 PM | #1555 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Im more mad that I won't hit 200k miles on the original motor. She was still purring at 175k, then CA ruined it for me
10-13-2020, 09:10 PM | #1556 | |
¯\_(ツ)_/¯
Drives: '15 ultramarine
I hope you get a new motor out of it. |
10-13-2020, 11:40 PM | #1557 |
Drives: 2013 pearl white FR-S
I have driven my car 600 miles post recall.. good thing I am selling it this weekend! No more headache!!!
10-14-2020, 02:06 AM | #1558 |
A buddy had his motor go having the recall done at the same dealership. He got a lower mileage used engine so that's what I am expecting at this point
10-14-2020, 08:33 PM | #1559 |
You guys getting replacement motors are making me sad. My car is a planter in the driveway since my motor blew in August 13 months and 16k miles after the recall work was done. Trying to sell it but that's tougher than it should be with all the cars with dead motors now.
10-14-2020, 08:51 PM | #1560 | ||
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | Opie (10-15-2020) |
10-21-2020, 08:34 PM | #1561 |
Screenshot from a video I was sent. They are claiming this is not enough sealant to cause starvation. Also pointed out that it is factory sealant as the recall uses gray sealant. Though that doesn't mean it isn't debris I guess
They are still doing more teardown to check internals. This is just what they got to so far
10-22-2020, 04:46 PM | #1562 |
Drives: Black 2013 FRS
Spun Rod Bearing - 19 months and 20k miles since recall.
Vehicle Mileage: 88k
Vehicle Make: Scion FR-S 2013 MT Mileage After Recall Performed: 20k Symptom(s): Cruising on highway, engine knocking, then stalled. Would not turn over. Failure: Spun Rod Bearing State: Pennsylvania Dealership Offering Repair: TBD. Recall done at Thompson Toyota, Doylestown, PA. Car is currently there, I’m awaiting further information. |
10-22-2020, 05:02 PM | #1563 | |
義理チョコ
10-22-2020, 05:05 PM | #1564 |
its shadow on the right side. I could see it clear in the vid. Its just the little chunks on the edges
The Following User Says Thank You to finch1750 For This Useful Post: | Ultramaroon (10-22-2020) |
10-22-2020, 07:29 PM | #1565 | |
Drives: 2013 BRZ Limited
Just because the sump isn't clogged doesn't mean the silicone at the valve cover gasket isn't blocking other areas. Right?
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
The Following User Says Thank You to dasting For This Useful Post: | Tcoat (10-27-2020) |
10-22-2020, 11:33 PM | #1566 | |
10-23-2020, 12:39 AM | #1567 |
And this was the reason I sold my car right after performing the recall... Didn't want to deal with this headache
The Following User Says Thank You to DarkSideFRS For This Useful Post: | Clipdat (10-24-2020) |
10-23-2020, 03:51 PM | #1568 |
義理チョコ
That doesn't look bad. Were the o-rings on the timing cover in place? Not distorted? If not properly seated on assembly, they pop out under pressure.
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Similar Threads | ||||
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
