Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-30-2020, 09:58 PM | #15 |
義理チョコ
Never mind the sound you hear when stopped. You are listening extra hard and have now noticed what's called neutral rollover, or something like that. It's the clatter of all your gears rotating freely but also getting kicked by the pulses of the engine at idle.
One thing about fifth is that the transmission isn't actually doing anything. It's a straight shaft from the front to the back. That you don't hear anything on acceleration means that it's not in the transmission. It is odd only hearing it during engine braking. Is the driveshaft rubbing on something? edit: nah. that's not driveshaft rubbing. Diff mount blown out?
10-31-2020, 07:36 AM | #16 |
Drives: 2014 GT86
5th is straight? Not 4th (for which reason usually used in dyno runs)? I thought that both 5th & 6th on ours were overdrive?
10-31-2020, 01:34 PM | #17 |
義理チョコ
They are for the automatic.
11-01-2020, 04:10 AM | #18 | |
Drives: 86
11-02-2020, 12:44 PM | #19 |
義理チョコ
Was the rear trans mount torn/blown? I saw your other post.
The Following User Says Thank You to Ultramaroon For This Useful Post: | ALWYZBZ (11-04-2020) |
11-04-2020, 03:25 AM | #20 |
Drives: 86
Trans mount was not torn or blown.
The rattling: Removing Whiteline Rear Diff + Whiteline trans bushing brought down the noise by 90%. The odd deceleration rattle is still feintly present but much more tolerable. The weird clunking: This was caused and fixed by centering the T bolt on the trans bushing. I guess it’s easy to overlook when tightening the bolt after removing the Whiteline trans bushing. |
The Following User Says Thank You to ALWYZBZ For This Useful Post: | Ultramaroon (11-04-2020) |
09-16-2021, 07:43 PM | #21 | |
Hold on! Same here!
I'm having the same issue! I just had an Action Clutch installed two weeks ago, and the second I left the shop, that buzzing started. It buzzes the most in 2nd, 3rd, and 5th gears for me. The owner told me it was because of my Verus Clutch fork... Has anyone found a solution? Or is it just a bad clutch kit? -PS. This is my first post I hope I didn't screw it up |
09-17-2021, 02:38 AM | #22 | |
義理チョコ
09-26-2021, 10:48 PM | #23 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
11-23-2021, 09:39 PM | #24 | |
Drives: 2016 scion frs
I have Whiteline diff cradle inserts and Whiteline position traction kit(rear subframe inserts) I removed the diff inserts and can confirm just removing that reduced most of the rattle, if not all. Removing the subframe inserts would probably eliminate all of it. I also have STI mounts if that matters. |
Similar Threads | ||||
Vibration at 2500rpm when decelerating | Andy2002a | Engine, Exhaust, Transmission | 9 | 11-09-2019 09:29 PM |
Vibration at 2500rpm when decelerating | Andy2002a | Engine, Exhaust, Transmission | 2 | 09-30-2019 11:23 PM |
Crunching Noise When Decelerating In 2nd/3rd | idkwhatimdoing | Issues | Warranty | Recalls / TSB | 37 | 01-10-2018 09:30 PM |
Hum/whine when decelerating | GeeTee86 | Issues | Warranty | Recalls / TSB | 10 | 08-11-2016 12:01 PM |
White smoke decelerating | azynneo | Engine, Exhaust, Transmission | 6 | 07-23-2016 10:14 AM |
