Old 02-23-2021, 08:27 AM   #29
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
One other point. If a daily driver stay away from light weight fly wheels. With what you plan the disadvantages will greatly outweigh (no pun intended) the advantages during normal driving. If a track only car then go for it as then the advantages will pay off.
I totally disagree. They are nowhere near as bad as they used to be. It takes some adjusting to get used to it but it isn't anything like the old school ones that made cars almost undriveable.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Tcoat (02-23-2021)
Old 02-23-2021, 08:48 AM   #30
I will concede the point I have not tried one since 1998 but do not understand how the physics would have changed since then.
What can be different about them that removes the issues?
Old 02-23-2021, 10:19 AM   #31
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
For a street use I wouldn't want the lightest option which for many seems to be around the 10 pound mark. Stock is 20 pound range from sources on here.
If stock is 20 pounds, knocking off 5-7 would be reasonable to keep some drivability.
Avo flywheel is 15 pounds and comp clutches is 12.6.
15 seems about perfect to me and 12.6 seem like next best for a street setup.
I've ran a 7 pound fidanza flywheel on my integra and it was a bit much for daily. Compared to stock Weight of 18 pounds.
Old 02-23-2021, 11:22 AM   #32
DarkSunrise
DarkSunrise's Avatar
12 lbs is fine for daily driving. I've got the Exedy 12.7 lbs one right now. Just don't pair it with an aggressive clutch and it works great.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
RToyo86 (02-23-2021)
Old 02-23-2021, 11:43 AM   #33
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I am looking at getting the Exedy lightweight flywheel later this year. Did you need to get your tune adjusted for the flywheel?
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
ermax (02-23-2021)
Old 02-23-2021, 12:48 PM   #34
why?
why?'s Avatar
Drives: series.blue
Two things. The first is the flywheels are not anywhere near as light as they used to be. I remember seeing 5 and 6 pound flywheels back then. Even the lightest now is about 12 pounds. The second thing is the clutch is so much better. You can get an aftermarket clutch the drives just like stock and can handle an extra 100 pound feet of torque. No more clutches that feel like you are driving a dump truck.
The Following 2 Users Say Thank You to why? For This Useful Post:
CSG Mike (02-24-2021), Tcoat (02-23-2021)
Old 02-23-2021, 01:08 PM   #35
DarkSunrise
No changes needed with my OFT 4.03 e85 tune. I haven’t tried it with stock tune.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
DocRecon (02-28-2021), ermax (02-23-2021)
Old 02-23-2021, 01:18 PM   #36
ermax
ermax's Avatar
I’ve never had negative impacts from FWs down to 12. I’ve never had any lighter that that but I’d imagine negative impacts to casual driving would start there. The only negative thing I can think of is no more tail waging shifts to 2nd which really isn’t a negative thing in my eyes.
Old 02-23-2021, 01:47 PM   #37
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by Jdmjunkie View Post
I have a single plate OS Giken setup and I can't recommend it enough! Break in was a bit off a pain but once that is over it is the best clutch I have ever driven, performance wise.
Is it this one ?
https://www.counterspacegarage.com/c...ch-system-fa20
Any chatter or judder @ idle, 2000rpm or other rpm?
Is the clutch heavier?
How do you like it as daily driving vehicle in traffic?
Thanks!
botbs is offline   Reply With Quote
Old 02-23-2021, 03:10 PM   #38
Jdmjunkie
Drives: Scion FR-S 10 Series
Originally Posted by botbs View Post
Is it this one ?
Thanks!
That is the one I would have purchased but OS Giken recommended their htr single because I track my car.
The pedal pressure is a bit heavier but there is much more feel so I find it easier to use. I also have the mtech clutch spring which I highly recommend!
There is no noise or shudder at all when the clutch is out, when the clutch is in it make the iconic Os Giken ringing noise from the floating pressure plate.
I would imagine the one from CSG would be even better for a daily then the one I have, I wish you lived closer as I would let you try it.
Just for perspective my 62 year old mother has no complaints driving my car!
Jdmjunkie is offline   Reply With Quote
The Following 2 Users Say Thank You to Jdmjunkie For This Useful Post:
botbs (02-23-2021), CSG Mike (02-24-2021)
Old 02-24-2021, 04:26 PM   #39
CSG Mike
CSG Mike's Avatar
Most folks who jump into my car with a STR pressure plate have zero issues driving it.
Also, I bet the CSG version didn't exist at the time you purchased, as the CSG single is a very new release, and specced out to try to fit as wide a range of "typical modification" 86's as possible, whereas the CSG twin disc was specifically made for high hp applications and track specific applications that didn't have any highly specialized clutch options at the time.
Jdmjunkie (02-24-2021)
Old 02-24-2021, 06:03 PM   #40
Jdmjunkie
Yeah it will be a year in March since it was installed. I am currently looking at their differentials, if they are anything like the clutch is should be another step in the right direction for my car. Do you have a CSG spec differential setup?
The Following User Says Thank You to Jdmjunkie For This Useful Post:
Old 02-24-2021, 07:51 PM   #41
botbs
botbs's Avatar
+1 on this
By the time I purchase the clutch, I want to order the CSG Spec 1.5Way OS Giken Diff (if available) as well.
The Following User Says Thank You to botbs For This Useful Post:
Old 02-24-2021, 09:25 PM   #42
CSG Mike
CSG Mike's Avatar
It's not a CSG spec differential, but rather, each LSD ordered from CSG has the option of being configured to match the driving discipline the car is used for, along with the tires used, suspension, and power output of the car. In some cases, aero is also taken into consideration.
In this instance, a CSG spec doesn't make sense, since it wouldn't work for everyone, or even a wide range of users.
OS Giken LSDs are currently backordered, but the next batch on order by CSG arrive at the end of March. At that time, each unit is opened up and configured as needed before shipping.
botbs (02-25-2021)
FS: OEM Clutch & Flywheel pleong Transmission and Driveline 2 10-14-2014 01:00 PM
Fs: act flywheel and clutch Guildjs Transmission and Driveline 9 05-18-2014 03:26 PM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
