03-12-2014, 01:15 AM | #547 | |
It's too difficult to pass a SD tune through the CARB process; you have to CARB each individual component that is replaced... |
The Following User Says Thank You to CSG Mike For This Useful Post: | jamesm (03-12-2014) |
03-12-2014, 02:08 AM | #548 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Met Oscar Sr & Jr tonight at the Irvine meet and they were great to talk to. Good to see they're just car regular guys that can talk car crap all night long.
The Following 2 Users Say Thank You to mit_peid For This Useful Post: | *LongFella (03-12-2014), CSG Mike (03-12-2014) |
03-12-2014, 02:16 AM | #549 | |
Drives: Attitude
03-12-2014, 02:55 AM | #550 | |
Drives: 2022 BRZ Limited
Since the coolant that circulates around the bigger/more capable radiator and the sandwich plate, it helps reduce the OIL temps as well. In other words, oil cooler combined with a bigger radiator behaves like a bigger oil cooler, it's like killing two birds with one stone. Let me explain why.. As opposed to air to oil cooler, there's no penalty of using the coolant to oil cooler (such as unwanted cool temps) in the cold days since when you first start the car, it bypasses the radiator to warm the engine (and the oil), thanks to the thermostat .. "cold doesn't necessarily mean better", "ideal temps" are better .. This was the case with many Corvette Grand Sport owners as opposed to newer Z06s' or ZR1s' oil cooler system ..GS utilizes the air to oil system and many people complained that it takes too long to warm up the cars in the morning.. With that said, this may not be an issue for the CA residents but I would still keep an eye on the oil temps during the winter
03-12-2014, 03:13 AM | #551 | |
I wonder if he still uses the factory radiator.. My friend ended up spending $1200 on his Z06 just to drop the temps from 260s to 230s and he was pretty happy with it also, I think Subaru keeps a good safety margin for their turbo engine cars and I believe it should provide adequate cooling.. just think about it they sell the same exact cars to South Africa to Arizona, Iceland to Australia ..I never had any heat soak issues with my previous STIs when I was driving them in hot summer days in FL ( no major mods of course) except the fact even my 5w-40 Rotella T6 was getting pretty bad after 2-3k miles.. Compared to TMIC w/turbo vs FMIC w/Rotrex SC I am pretty sure it generates a lot more heat
The Following User Says Thank You to glamcem For This Useful Post: | Calum (03-12-2014) |
03-12-2014, 03:15 AM | #552 |
once I finalize my setup ( hopefully I can arrange the funds soon), I will definitely report back and provide before and after logs
03-12-2014, 08:56 AM | #553 | |
Drives: 2014 Scion FR-S|Whiteout
Absolutely agree! The last two times I went to their shop I find myself engulfed in conversation listening and learning for a few hours over expresso. Great Company and great family business
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
03-12-2014, 12:25 PM | #554 | |
I run an oil/water on my S2000, and we run oil/water coolers on the boosted CSG s2ks. My last oil change went for 12k miles. Yes, 12k on the same oil. It's amazing what you can get away with when a system is properly spec'd out. I've recommended the Cusco oil/water cooler to several boosted FRS/BRZ owners, who have heavy space constraints. |
The Following User Says Thank You to CSG Mike For This Useful Post: | glamcem (03-12-2014) |
03-12-2014, 12:25 PM | #555 |
03-12-2014, 12:32 PM | #556 |
Drives: 2013 FRS / 2013 427 Vert
Mike, are you aware of anyone combining the JR system with a Robi-Cooler yet?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
03-12-2014, 12:48 PM | #557 |
03-12-2014, 12:57 PM | #558 | |
Maybe it's the noob status, but I'm still struggling to see where/how an oil/water cooler is efficient enough for heavy driving? I understand the larger radiator might help cool the coolant more and in turn, help with the oil... but your still passing such a small amount of coolant through a little tiny donut for milli seconds.... Oil to air gives you a larger satreb up front which holds a good amount of oil... so my brain tells me a lot more oil is getting colder faster than in this little donut piece by the filter... As long as air is passing through the front I'm good... If no air... That's where I can see an issue... but the car's typically always moving... Need to do more research, I must!
03-12-2014, 01:05 PM | #559 | |
The real function of the "oil cooler" on the Forester is actually an oil heater. It brings the oil up to operating temperature faster in colder climates, because the coolant is actually warming the oil. It only cools the oil if the coolant is cooler than the oil. E.g., 2 minutes after starting, if the oil is 100F, and coolant is 180F, the coolant is warming the oil. Likewise, 80F ambient vs 240F oil with a large surface area will cool the oil more, than 190F coolant vs 240F oil with a tiny surface area. Yes, the specific heat of Water is spectacularly high, but not enough to compete with a proper oil-air cooler in this application vs a Forester cooler. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (03-12-2014), sklimo (03-12-2014) |
03-12-2014, 04:34 PM | #560 | ||
What could be considered as the dangerous operating oil temp for these cars? With the Vette, I always tried to keep it below 260 ( was doing a few cool down laps even with the air-oil cooler) . 230-240F didn't sound much here's a video of my Grand Sport which I traded for the Miata [ame="https://www.youtube.com/watch?v=-xje4jWGll4"]https://www.youtube.com/watch?v=-xje4jWGll4[/ame] Quote:
Tags |
jackson racing, jrsc, rotrex, supercharger, track |
Similar Threads | ||||
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 03:28 PM |
Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 02:29 PM |
