10-24-2013, 09:27 AM | #2395 | |
Drives: DGM BRZ limited
At the worst and no one can figure out how to trick it from the wires going to the volt meter, just open the thing up and wire a small relay across the switch contacts. Atleast then you won't possibly be affecting system performance. Also, depending on how constant these things can pull 3.5 and 4.5kw, that relay wouldn't be strong enough anyways. |
10-24-2013, 09:48 AM | #2396 |
Drives: 2013 BRZ Limited
Fenton or Rob...
Is there a way you might get an ESC to Unichip so they can make a map for the system? This would help me out...as well as open up a new potential market for both Rob and Unichip. |
10-24-2013, 10:09 AM | #2397 | |
Drives: WR Blue BRZ, 240Z
Rob will have to comment on the suitability of a 100A continuous duty contactor. 3500watts @ 24VDC equates to 145A. However I don't know if that is inrush power or duty cycle. The contactor I linked has a 400A inrush capability.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
10-24-2013, 10:21 AM | #2398 | |
Currently you have the option of ecutek or brz edit which is a great start. These are the two most powerful software options that allow full data logging to make sure everything is running right. Now there is always options for people to go to different platforms.... I think someone is working with open flash tablet right now to get a base map. As time goes on there will be more and more options but you want to make sure the choice you make is going to be a safe one. If it isn't designed for FI with data logging you would be taking a risk. Rob hasn't sent any kits to any vendors.... He wants the everyday people to get a chance to test it, beat on it and make mistakes that all humans do. Sent from my HTC One using Tapatalk |
10-24-2013, 10:42 AM | #2399 |
Drives: VW
All who are running the system: The green an yellow wire need to be open for 100% shut down. A DPDT relay, 12V/2-5 Amp, can be soldered in as shown. The relay coil can be activated by a switched 12V (Best to find a switched 12v+ in the fuse box next to the controller.) @Pug did something similar, but integrated it into his LCD screen. @GaryNJ, no need for the heavy contactor Rob |
10-24-2013, 10:56 AM | #2400 |
Drives: Raven FR-S
Gotta love Rob's proactive nature to improve the product.
The Following User Says Thank You to Thatruth2001 For This Useful Post: | DAEMANO (10-24-2013) |
10-24-2013, 11:11 AM | #2401 |
Drives: Subaru BRZ
Rob,
Do you have a part number for the relay? Is that something that is readily available? |
10-24-2013, 12:26 PM | #2402 | |
Drives: VW
Or....you could go old school...mounted on the dash http://www.radioshack.com/product/in...ductId=2062538 |
10-24-2013, 12:29 PM | #2403 | |
So we need jump a fuse in the fuse box for something that is always on when the ignition is on...say the instrument cluster or the HVAC fan. Using a multimeter I can determine which side of the fuse socket is the protected side. Yeah, if you have a part number of a suggested DPDT I'll solder this in to the wire harness.
The Following User Says Thank You to Gary in NJ For This Useful Post: | Robftss (10-24-2013) |
10-24-2013, 07:46 PM | #2404 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Quick response: System is now working. Feels great. More later.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
The Following User Says Thank You to Sojhinn For This Useful Post: | Robftss (10-24-2013) |
10-24-2013, 09:50 PM | #2405 |
Just as a quick reference to Rob and anyone else. An easy way to tell if one of your batteries is bad is when the batteries charge quickly. I.e they hit full charge within a couple of seconds after a long wot.
Also I'm hitting the cel like crazy. Any luck with toma rob?
The Following User Says Thank You to Sojhinn For This Useful Post: | Thatruth2001 (10-24-2013) |
10-24-2013, 10:00 PM | #2406 | |
Drives: Raven FR-S
10-25-2013, 01:33 AM | #2407 |
Drives: Subaru BRZ
Installed the relay but haven't been able to find a switched 12v supply in the engine fuse
block. Most of the fuses have power all the time or not at all. Anybody else try it? |
10-25-2013, 01:34 AM | #2408 |
Any chance you have An aftermarket radio?
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
