08-04-2022, 09:19 PM | #491 | |
Drives: Crapcan
Where is that picture from? Procedure is to apply to the lower pan, not the upper pan.
08-04-2022, 10:03 PM | #492 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (08-04-2022) |
08-04-2022, 10:36 PM | #493 | |
Drives: Crapcan
Potential Cause of rumored GR86’s blown engine? Seal packing(RTV) was peeled off
No I am wrong, it is the upper assembly that gets the FIPG applied.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | gcmak (08-04-2022), Ultramaroon (08-04-2022) |
08-04-2022, 10:40 PM | #494 |
義理チョコ
I was too lazy to verify. I only suspected it. Shame on both of us.
08-04-2022, 10:56 PM | #495 | |
Drives: Crapcan
Engine is always upside down on the stand.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (08-04-2022), Ultramaroon (08-04-2022) |
08-04-2022, 11:37 PM | #496 | |
Drives: GR86
The Following User Says Thank You to gcmak For This Useful Post: | MyHybridBurnsGasAndTires (08-05-2022) |
08-05-2022, 12:02 AM | #497 |
ProCrastinationConsultant
that's great, do it yourself. but how do you know you're not applying even more and creating the same problem all over again?
the question i still don't understand is why doesn't everyone make their own gasket for this?!? it appears to be 2 singular parts touching, so there's no extra sealant needed to seal the seams between engine halves... so grab some gasket material, and cut to fit...
The Following User Says Thank You to soundman98 For This Useful Post: | Jdmjunkie (08-05-2022) |
08-05-2022, 12:41 AM | #498 |
Drives: "I drives like a Porsche"
We are all fd in the A!!!!!
08-05-2022, 01:43 AM | #499 |
Drives: Gr86
He probably added more silicone than was there in the first place…
Also, the silicone that gets stuck in the pickup doesn’t only come from the oil pan. It can come from the front timing cover mating surface as well. It can continue to break off from there and plug up the pickup. |
The Following 4 Users Say Thank You to Ronac For This Useful Post: |
08-05-2022, 01:55 AM | #500 |
Drives: 2022 GR86
We really need to figure out how to inspect and clean the oil pickup tube without taking the oil pan off.
Someone on FB posted that his Subaru techs were able to take a photo of his filter mesh without taking the pan off.
Follow the build thread for my GR86!
08-05-2022, 02:14 AM | #501 |
Drives: zd8 brz
yea see that's impossible.. like physically impossible, especially at the angle that photo was taken
The Following 3 Users Say Thank You to mycrors7 For This Useful Post: |
08-05-2022, 02:20 AM | #502 |
Drives: 2022 GR86
Great catch, that photo was clearly taken from a few inches "down" from the tip of the pickup tube!
The Following User Says Thank You to timurrrr For This Useful Post: | mycrors7 (08-05-2022) |
08-05-2022, 02:24 AM | #503 |
義理チョコ
Way too much is being made of this. I don't endorse this preemptive DIY disassembly of the engine. I certainly don't endorse publishing amateur youtube videos of sloppy work, but it's a free internet. Have at it.
08-05-2022, 03:13 AM | #504 |
Drives: zd8 brz
Tbh all someone has to do is weld on a bung right where the oil pickup is and have a plug there. Drain oil, pull plug, use long pick to clean out the excess rtv, plug it up and repeat every oil change as a precaution
Or just full send cause it being a Subaru boxer it’s likely going to go kaboom one way or another |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
