Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
12-19-2022, 11:30 AM | #29 |
Drives: 2013 Subaru BRZ
Code p0441
well if anyone is still following this, P0441 is a bullshit code and it was actually the leak detection pump valve assembly. has nothing to do with the purge valve, lines, or gas cap. The whole rear subframe is being dropped tomorrow to even get to it. price to fix is about 1300.
The Following User Says Thank You to Jynx For This Useful Post: | blsfrs (12-19-2022) |
12-19-2022, 03:52 PM | #30 | |
Drives: 2013 frs base
12-19-2022, 04:47 PM | #31 |
Leak detection pump valve assembly. also referred to as the canister pump module. it is located right next to the charcoal canister. Sent from my iPhone using Tapatalk Last edited by Jynx; 12-19-2022 at 06:09 PM. |
The Following User Says Thank You to Jynx For This Useful Post: | blsfrs (12-20-2022) |
12-20-2022, 01:45 PM | #32 | |
12-20-2022, 02:04 PM | #33 | |
wrong. wasn't the purge valve. everyone tried to tell me it was the one under the intake. the one in the back is not a "purge valve" Sent from my iPhone using Tapatalk |
12-20-2022, 02:29 PM | #34 |
Doesn't change that the test pump is a part of the whole system no matter where the purge valve is located.
12-20-2022, 02:45 PM | #35 |
義理チョコ
"Everyone..." You didn't look at the service manual at all, did you?
12-20-2022, 02:46 PM | #36 |
The Following User Says Thank You to Jynx For This Useful Post: | Ultramaroon (12-20-2022) |
12-20-2022, 03:10 PM | #37 |
義理チョコ
lol... that SUCKS!
12-20-2022, 05:32 PM | #38 |
at the moment the car is looking good but they are gonna keep testing it to make sure that this is actually it.
12-21-2022, 04:38 PM | #39 |
haha sike, that did not fix it.
12-22-2022, 11:11 AM | #40 |
Did they replace everything? Pump, module, canister? While it was disassembled, did they smoke or pressure test all of the lines?
12-22-2022, 11:18 AM | #41 | |
yes they did everything u just stated lol. now we are thinking a PCM issue because the PCM isnt even controlling the valve in the front and is only partially giving a signal to the one in the back. it just became a lot more money lmao Sent from my iPhone using Tapatalk |
The Following 3 Users Say Thank You to Jynx For This Useful Post: |
01-03-2023, 06:59 PM | #42 |
Update ~ ECU is getting checked tomorrow and may have to go the dealership to get completely replaced and reprogrammed. (if anyone is still following.) |
Similar Threads | ||||
Help diagnosing P0441 code | 1Saucyyy_brz | Issues | Warranty | Recalls / TSB | 3 | 09-18-2022 05:45 PM |
Engine code p0171 and p0441 | frscory | Issues | Warranty | Recalls / TSB | 6 | 02-20-2022 06:06 PM |
Having trouble with code p0441 | Jynx | Issues | Warranty | Recalls / TSB | 5 | 02-19-2022 05:17 PM |
p0441 cel code | bryan.catano93 | Engine, Exhaust, Transmission | 5 | 03-12-2018 11:38 AM |
Check engine code P0441 | Gibson | Engine, Exhaust, Transmission | 0 | 11-23-2016 05:39 PM |
