Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
10-27-2016, 04:42 PM | #15 | |
Does the voltage drop before, or after, the engine sags?
The Following User Says Thank You to wparsons For This Useful Post: | Ultramaroon (10-27-2016) |
10-27-2016, 08:05 PM | #16 |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
I have a voltage meter on my radar detector, the voltage hunts all over the place anyway depending on the electronics. It'll dip like crazy if you're playing music, rolling down the window, if the fan cycles, AC turns on or off... probably more if your battery can't provide the instant power the car requires and it leans on the alternator more often. That may be the side effect of using a lightweight battery.
If you use a stock battery, it takes a little while for a standard battery to provide power on demand. AGM batteries like optima and similar can provide it a little faster. I have absolutely no idea how a motorcycle battery would work for that purpose but it's entirely possible you've overtaxed the alternator. Gas quality was my problem briefly, I just went back to Costco but I'll probably throw a tank of shell in there every so often. FYI, I learned the detergent they use for top-tier status is Lubrizol. |
10-27-2016, 09:35 PM | #17 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
It hasn't stuttered in a few days so currently going off the voltage reading.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
10-27-2016, 09:39 PM | #18 |
Just the tip
If I hold it at 2000rpm, the last couple days it's usually at 14.1 or so within .1. Sometimes the voltage will drop but it's not happening as frequently the last 2 days since spraying the MAF with cleaner. When it does drop the last couple days it's been as high as 14.3 and as low at 13.0, but I can't keep my eye on it while driving. I tried to have it parked in my garage and rev it and it seemed fine.
10-27-2016, 10:50 PM | #19 | |
義理チョコ
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soundman98 (08-08-2021), wparsons (10-28-2016) |
10-28-2016, 03:16 PM | #20 |
Drives: 1996 ST204, Series 10 FR-S
If your voltage/charging system is intermittently charging, it could be worn alternator brushes. If you have over 60k miles on it, it could be a possible. Our ECUs also control the voltage regulator to turn off while acceleration to help with fuel consumption so keep that in mind.
The Following User Says Thank You to projek_01 For This Useful Post: | stockysnail (10-29-2016) |
08-07-2021, 03:27 PM | #21 |
Drives: 2013 Blue 6MT FR-S
Apologies for reviving this ancient thread but it's the closest one I could find relevant to my current problem.
Stockysnail, did you figure out the source of your problem? I'd been using a lightweight battery similar to yours for like 80,000 km and it suddenly just died. My new group 35/550 CCA replacement battery's voltage is fluctuating between 12.11 V and 13.15 V while idling and hasn't gotten above 14 V. My battery warning light has come on and off twice and I've noticed that the battery charges when the light is off. The problem has been going on for about 2 days now and I'm wondering if it's likely my alternator. Any thoughts? |
08-07-2021, 04:30 PM | #22 |
義理チョコ
ECU controls charge rate. It's normal for voltage to fluctuate. I haven't yet read of any alternator failures that didn't affect power steering but just in case...
https://gt86stuff.onrender.com/t3Por...01AR909JX.html
08-07-2021, 06:09 PM | #23 |
The Stig's African Cousin
Drives: 2014 wrb brz
I had 110k to 120k miles on my brz before I replaced my alternator. Mine was making a loud rattle noise so it was easy to determine it was going bad. I don't remember it popping any cels though.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
08-10-2021, 05:00 PM | #24 | |
Yeah, I should've mentioned the power steering failure happened then the car stopped running within 5 more minutes of driving. I don't have both an ammeter and voltmeter to simultaneously check voltage and current, but at 2000 rpm when reading just the voltage across terminal B of the alternator to ground it reads about 5.7 V which is really low. Do you know if the voltage reading is meaningful without measuring current across terminal B simultaneously? |
08-11-2021, 12:44 AM | #25 | |
義理チョコ
08-17-2021, 02:15 PM | #26 | |
The Following User Says Thank You to BlueBoy For This Useful Post: | Ultramaroon (08-17-2021) |
08-17-2021, 02:23 PM | #27 |
義理チョコ
Great to hear. Happy motoring!
Similar Threads | ||||
My battery keeps dying | mynameis940 | Issues | Warranty | Recalls / TSB | 22 | 02-28-2015 11:52 PM |
Is there a DIY/FAQ on re-dying the interior stitching? | Michael Blue | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 08-29-2014 12:34 PM |
Dying to hear this!!! | sweetfrs | Engine, Exhaust, Transmission | 8 | 09-19-2013 09:17 PM |
I'm dying over here! | coastertrav | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 04-15-2013 06:41 PM |
Forum is Dying | #87 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 06-08-2010 11:36 PM |
