12-18-2015, 01:16 PM | #85 |
12-18-2015, 01:30 PM | #86 |
Drives: 17 Alfa Romeo 4C
Itchi, Itchi ... Are you there?
12-18-2015, 01:34 PM | #87 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
I always suspected that he was just another Zik/GTX/Cedars reincarnation. |
The Following User Says Thank You to KR-S For This Useful Post: | Cole (12-18-2015) |
12-18-2015, 01:38 PM | #88 |
Newbie
Drives: Gt86
12-18-2015, 01:40 PM | #89 |
Sporadic Member
They don't need any other links to see that the links you posted up come from biased websites.
12-18-2015, 01:45 PM | #90 | |
Drives: 2013 Brz C38 (bought not built :P)
That being said both would have residue at the same height which could possibly cause the issue whether the tank is full or not the concentration would only be lower in the full tank -++++- -+--+---+--+ here is a visual representation, the + being residue it would still be possible/likely that it would intake said residue just in smaller amount meaning that your logic is flawed since a full tank would also cause those same issues just at a slower rate or at with slightly less important consequences. (will take 2weeks to gunk up instead of 2 days or will completely block injectors vs will partially block them. In both instances there would be blockage though and since that is not the case your theory/hypothesis is invalid) |
12-18-2015, 01:46 PM | #91 |
You like random internet stuff so much here you go (coincidently enough it says almost exactly what I said from the start)
http://www.bankrate.com/finance/auto...r-myths-1.aspx
12-18-2015, 01:50 PM | #92 | |
You also get a higher risk of getting hit by a car if you go outside, but there is no real direct link with going outside vs being ran over just like there is no real world effect of a full tank vs almost empty one (at least not since this millennium) |
12-18-2015, 01:52 PM | #93 |
But Dude, one of those links says in winter to wash your car using Pledge furniture polish. You do not get any more official than that!
12-18-2015, 01:52 PM | #94 |
Hum I use brakes and actually have enough dexterity to remove my foot from brake, while simultaneously applying throttle and releasing the clutch. Which btw is the proper way to do it. You want driving courses on top of your introduction to physics/chemistry 101?
12-18-2015, 01:54 PM | #95 |
@Tcoat it was written on the internet so according to him it must be true.
you should also put sugar in your gas tank to fight those residues sandpaper on wiper to remove the ice Mike probably has a great intake he could build for you curb feelers? no wait these actually have a use so he wouldn't think of using them |
The Following User Says Thank You to fumanchu1 For This Useful Post: | KR-S (12-18-2015) |
12-18-2015, 01:59 PM | #96 |
Site Moderator
Drives: ichi 86 Project
Who's "Itchi"? You mean "ichi"? Yes, I'm here enjoying my popcorn
First part of concern is resolved, but cricket & gas debate is still going. If I miss some comment which breaking the rule, lmk. |
The Following User Says Thank You to ichitaka05 For This Useful Post: | KR-S (12-18-2015) |
12-18-2015, 02:05 PM | #97 | |
Sporadic Member
The Following User Says Thank You to KR-S For This Useful Post: | go_a_way1 (12-18-2015) |
12-18-2015, 02:06 PM | #98 |
don't need links to discredit obviously biased marketing material with no sources. Also several people including @Tcoat have already provided links that mentioned the things you said claiming they were myths and had no supporting evidence to back up their claims.
