Old 03-31-2016, 09:01 PM   #99
thien
Drives: Scion FRS
Pages after pages of useless information lol. Check 1 fuse. Cures all those symptoms.
Sent from my SM-G920T using Tapatalk
thien is offline   Reply With Quote
The Following User Says Thank You to thien For This Useful Post:
1GiantTurtle (03-31-2016)
Old 04-11-2016, 02:07 PM   #100
Sapper211
Drives: 2015 FR-S and 2014 IQ
This thread should be required reading for most high school kids.
Sapper211 is offline   Reply With Quote
The Following User Says Thank You to Sapper211 For This Useful Post:
1GiantTurtle (04-14-2016)
Old 04-11-2016, 02:12 PM   #101
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
Originally Posted by HotLavaChick View Post
your mothers clit ring must have interfered
Gawddamn my office got hot just from my reading this
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following User Says Thank You to mixtape For This Useful Post:
go_a_way1 (04-11-2016)
Old 07-01-2016, 10:56 PM   #102
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
I fixed it for @thien check HAZ fuse under hood,
BCU searching for hazard/blinker relay
you saved me. Thanks!
phanguy is offline   Reply With Quote
The Following 2 Users Say Thank You to phanguy For This Useful Post:
1GiantTurtle (07-02-2016), thien (07-02-2016)
Old 02-26-2017, 03:02 PM   #103
UF Key Master
UF Key Master's Avatar
Drives: 2013 Toyota FRS Ultramarine
4 days without a car and dozens of hunting solutions under the dash all for the simple solution of replacing the Haz fuze in the engine compartment. THANK YOU! No more taking the cable off the battery to turn off the high beams and everything else works fine.
UF Key Master is offline   Reply With Quote
The Following User Says Thank You to UF Key Master For This Useful Post:
1GiantTurtle (02-26-2017)
Old 03-19-2019, 03:03 PM   #104
waifu_zn6
waifu_zn6's Avatar
Drives: 2015
I just had a similar issue when my fender garnish turn signals fell off. Dashboard lights wont turn off, it thinks the highbeams are on, and cant turn on my head lights and turn signals.
Anyone had the same thing happen to them and found the solution?
waifu_zn6 is offline   Reply With Quote
Old 03-19-2019, 03:46 PM   #105
waifu_zn6
waifu_zn6's Avatar
Drives: 2015
Me three! Saved me a trip to the dealership. lol
Thank you
Old 11-20-2021, 09:04 PM   #106
TunaNoCrus96
Drives: 2013 scion frs
Help I'm having these exact issues and have tried all that has been mentioned. Has anyone had or fixed this issue before. The last thing I'm gonna try is replacing the light switch on the steering wheel stalk but was wondering if any other information came out. Any helps appreciated for now my damn headlight are on a standalone switch.
of course. I have toyoguard- towed it to dealesrship-
tow truck guy and my 4 friends were helpful too. but we are all clueless -- pulled and checked all fuses. even put original relay back on. with relay even off it thinks high beams are on -- blinkers will not blink anymore but just stay on as running lights -- side markers and tails and gauge cluster all stay on as well.
but funny thing -- low and high beams won't power on anymore (hence why i had to tow it since I couldnt drive home).
it was about to drain the battery since it won't shut off. i pulled and put NEW fuses in even.
only thing i can think of is the aftermarket hyperblink relay + switchback leds shorted something and now the car's electrical is freaking.
i do have HID -- i took them off and put stock back on -- still nada.
let it sit with battery disconnected --- it would then be fine but as soon as i started the car again --- same, the alert alarm beep like i left the lights on and tried locking it and walking away and not being able to turn on low beams.
TunaNoCrus96 is offline   Reply With Quote
Old 11-21-2021, 10:13 AM   #107
Did you try replacing the haz light fuse as mentioned? If out that have you swapped out the BCU? Did it happen when you put in aftermarket lights?
Old 12-30-2021, 05:54 PM   #108
Frs2015california
Drives: Scion frs 2015 problem with my ligh
Hey what was the problem I'm having the same problem right I'm getting crazy with my lights how do you fix it
Frs2015california is offline   Reply With Quote
Old 03-20-2022, 12:04 AM   #109
Ashikabi
Ashikabi's Avatar
For future readers: just had this exact issue. Hazard fuse in the under hood fuse box was blown. Replaced fuse, everything is good now. Craziest symptoms I've ever heard of. But it is what it is. Check your fuse, it's 15amp
Old 03-20-2022, 01:54 PM   #110
Bigger question is why did the fuse blow in the first place?
Fuses don't usually blow for no reason.
Old 03-20-2022, 02:19 PM   #111
Ashikabi
Ashikabi's Avatar
Testing blinker connecter for a lighting install. Used a multimeter. I was informed by a mechanic friend that the multimeter can pull extra amperage, unlike a test light. So it seems that any increased load in the blinker system can pop this fuse and cause the craziest symptoms. So I'm my case, improper testing technique blew the fuse
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
bcj (03-21-2022), Tcoat (03-20-2022), x808drifter (03-21-2022)
Old 03-21-2022, 06:53 PM   #112
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
That is exactly OPPOSITE of what is true.
A voltage meter is the correct tool to test modern vehicle circuits, NOT a test light.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Search this Thread:
Advanced Search
Turn signal lights whip Cosmetic Modification (Interior/Exterior/Lighting) 13 02-26-2015 10:45 PM
Is there another way to keep the turn signal lights on? DeadStar7 Scion FR-S / Toyota 86 GT86 General Forum 10 06-29-2014 10:43 PM
OEM fog lights to turn on with parking lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 7 02-27-2014 06:41 AM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 02:13 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
