Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 12-02-2021, 07:45 PM   #43
Opie
Opie's Avatar
Drives: '13 BRZ TLM Spec
Originally Posted by slimfit View Post
Just to reiterate, we’re 100% sure that gen 1 kits will fit…right? Kinda hoping to do the CTS-V swap!
AP Sprint kit is not a direct fit replacement. Caliper bracket doesn't mount to the new aluminum knuckles due to a design difference. I would believe that Essex is working on a bracket to address this.
This may not affect performance pack Brembos.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
Code Monkey (12-02-2021), slimfit (12-02-2021)
Old 12-02-2021, 08:14 PM   #44
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Oh wow. What is the source of this info?
Can you elaborate?
Why does it work for Brembos, but not AP?
I presume AP will work with GR86 though?
timurrrr is offline   Reply With Quote
Old 12-02-2021, 08:56 PM   #45
Opie
Opie's Avatar
I have a 2013 with the original steel knuckles and run the Essex Sprint AP kit, I purchased the 2022 Aluminum knuckles (for the weight savings) and started the install tonight. An OEM caliper will bolt to the aluminum knuckles in the same fashion as the steel knuckles (and previously documented to fit). Since the AP kit, and most other aftermarket kits, use a bracket to attach to the knuckle instead of a caliper with the mounting points cast in it. The PP Brembos also use a bracket cast into the caliper in the same fashion as the regular calipers. So it will likely work without issue.
See pics, holes are in the same orientation, but the extra aluminum casting (likely for strength that steel doesn't require) blocks the AP caliper bracket from sitting flush, or in the correct orientation.
The Following 8 Users Say Thank You to Opie For This Useful Post:
Code Monkey (12-02-2021), DarkSunrise (12-10-2021), Pat (12-02-2021), Pete (12-02-2021), Scargod (02-15-2022), Stonehorsw (12-02-2021), timurrrr (12-02-2021), trippinbillies40 (12-02-2021)
Old 12-02-2021, 09:20 PM   #46
s30series
Drives: 2015 BRZ Series.Blue
Just put the stock brakes back. Lots of forum members say upgraded brakes are worthless on the BRZ and stockers will do just fine with good pads and fluid.
s30series is offline   Reply With Quote
Old 12-02-2021, 09:23 PM   #47
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Ah that makes more sense!
So basically there's some extra material added for reinforcement on the aluminum knuckle right where some aftermarket BBKs put their brackets.
So likely not an issue on GR86.
Those photos are super helpful, thanks a lot!
The Following User Says Thank You to timurrrr For This Useful Post:
Opie (12-02-2021)
Old 12-02-2021, 09:41 PM   #48
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Can we ban this guy yet?
Nobody said they're worthless. I (not everybody) responded saying upgraded brakes aren't necessary for track days because with good pads and fluid, they won't fade. I also said and agreed with you that there ARE benefits to better brakes, and even stated I intended on buying an aftermarket kit. But are they absolutely necessary to prevent fading or do a track day? No.
trippinbillies40 is offline   Reply With Quote
The Following 5 Users Say Thank You to trippinbillies40 For This Useful Post:
DocWalt (12-13-2021), Kona61 (12-12-2021), OkieSnuffBox (12-03-2021), Scargod (02-15-2022), ZDan (02-16-2022)
Old 12-10-2021, 03:42 PM   #49
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
@trippinbillies40 Are the pads the same size/shape as the gen1? Since the AP kit won't fit I'm suddenly in need of some track pads for the stock caliper.
14stu is offline   Reply With Quote
Old 12-12-2021, 04:42 PM   #50
Opie
Opie's Avatar
Yes, OEM pads are the same shape
Old 12-13-2021, 09:39 AM   #51
Fletch
Drives: 2022 BRZ Limited
Hello. New to this forum as i've just bought a shiny new 2022 BRZ which im planning to use as a dedicated track car. I haven't owned any previous gen BRZ/86s.
Reading through this thread im a little unclear if peoples opinions are based on the previous gen or the new one..
So I was wondering if anyone has heavily tracked their 2022 models yet with the stock calipers and rotor size, and if so, how are they holding up?
I want to figure out whether I can get away with just a rotor/pad/fluid/lines upgrade rather than a BBK. I notice the new model has built in ducting where the old model didn't. That's pretty much the limit of my knowledge
Fletch is offline   Reply With Quote
Old 12-13-2021, 09:51 AM   #52
jvincent
jvincent's Avatar
I doubt anyone has had a chance to really heavily track the current one.
Unless you are super fast on a track that is hard on brakes there is enough stopping power with upgraded pads and fluid.
That said the arguments for a BBK are only slightly different than the first gen assuming you are not adding a turbo or supercharger.
Gen 2 has slightly more power but better airflow so thermal management is probably a wash when it comes to pad temps. That leaves the primary argument for a BBK to be a financial one.
I can't remember who did the math but if you track a LOT then a BBK pays for itself in consumables after a certain number of days simply because you go through pads/rotors less quickly.
Old 12-13-2021, 10:03 AM   #53
eeghie
eeghie's Avatar
Drives: 1M
I have a 2013 with the original steel knuckles and run ..., I purchased the 2022 Aluminum knuckles (for the weight savings) ...
Did you happen to measure weight difference?
eeghie is offline   Reply With Quote
Old 12-13-2021, 10:42 AM   #54
Fletch
Thanks for the reply and the useful info! I should have clarified that my concern is about fade/failure rather than stopping power.
I'm a mid-strong level amateur/club racer (lots of guys still faster than me!). This car is going to be used for practice and tuition. The tracks in SoCal aren't particularly hard on brakes but I have managed to cook a couple of high-hp street car brakes to failure on them in the past.
Old 12-13-2021, 11:28 AM   #55
ZDan
ZDan's Avatar
Drives: '23 BRZ
The right pads and fresh DOT4 or DOT5.1 (but NOT DOT5!) fluid should work fine. Shouldn't be any need for aftermarket rotors and brake lines.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
DocWalt (12-13-2021), PBR (03-01-2022), timurrrr (12-13-2021)
Old 12-13-2021, 11:36 AM   #56
jvincent
jvincent's Avatar
You'll be fine with just pads and fluid if fade/failure is your main concern.
Performance Pack Brembo Rear Brakes Chuckable Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-20-2023 02:55 PM
Performance pack brakes Jdmuscle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-11-2019 05:05 PM
FS; Brembo Brakes Performance PCKG 900 miles brz/frs sokol Brakes, Suspension, Chassis 21 02-27-2019 01:15 AM
RB Performance Brakes BBK for Scion FR-S & Subaru BRZ RB Performance Brakes Brakes, Suspension, Chassis 9 06-04-2014 05:52 PM
