Old 11-25-2022, 08:31 AM   #15
I'm confused. Didn't they all have keyless entry? My '15 base has keyless entry and a trunk button on the fob.
Ya they all had a fob button to unlock the door but I meant touch to unlock.
Old 11-25-2022, 10:29 AM   #16
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
IF i remember correctly an actual trunk button to unlock the trunk from the outside wasnt added until one of the refresh years.
You had to either use the keyfob, the trunk release button on the drivers side of the dash, or the hidden physical keyslot where the rear license plate lights are.
Im guessing its one of those early "cost saving" measures to keep the price of the car down back when it was first released.
Old 11-25-2022, 11:01 AM   #17
The button only exists with the keyless start system.
The FRS did not have keyless entry (NOT pushing the button on the fob).
The FRS special editions that had keyless did have the button.
The early BRZ higher trim did have keyless and they had the button.
The base 86 does not have keyless entry so still did not have the button.
The later 86s in the higher trim did and they had the button.
The button needs the keyless entry/pushbutton start fob to always be transmitting to operate.
2014 BRZ manual shows the button.
bcj (11-25-2022), Sasquachulator (11-25-2022)
Old 11-25-2022, 11:30 PM   #18
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Just so it doesn't happen again, they do make a button "cover" for the trunk / valet lock out.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Trunk Cancel Button Pressed, But Lock Seized DjDATZ Issues | Warranty | Recalls / TSB 18 10-20-2021 09:19 PM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 10:50 AM
Small trunk lock hint here ……. humfrz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 05-29-2016 05:52 PM
Found: FRS trunk, please lock thread R3AP3R_Playz Want-To-Buy Requests 1 05-16-2016 06:24 PM
Keyless Lock Problem bdbx18 Electronics | Audio | NAV | Infotainment 5 01-18-2013 12:29 AM
