Old 08-28-2013, 05:00 AM   #43
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
nominate this for DIY directory.
@WingsofWar ?
EvilBeaverFace is offline   Reply With Quote
The Following User Says Thank You to EvilBeaverFace For This Useful Post:
WingsofWar (08-31-2013)
Old 09-03-2013, 05:26 PM   #44
Iamthebatman
Drives: Black Subaru BRZ
Nominate instantly adding any DIY @F1point4 posts to the DIY directory no questions asked!
:happy0180:
Iamthebatman is offline   Reply With Quote
Old 09-17-2013, 03:54 PM   #45
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by F1point4 View Post
This! As you saw in my photos, one of my bolts had growth on it. Barnacles? I think it was exposure to seawater or something during transport. I'm not sure what this means long term.
20121028-WhitelineRearCrossmemberBushingsDIY-20 by VictorN07, on Flickr
Just did mine today, had the same nasty bolt on the passenger front, driver side was fine.
Old 03-14-2014, 11:01 PM   #46
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
DIY - Whiteline Rear Crossmember Mount Insert Bushings
Yes, thanks for your DIY!
Front subframe bolts are fine for me :
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 07-02-2014, 04:53 PM   #47
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
After staring at the bag of bushings I bought for months I finally got to install them today. This guide was immensely helpful. Thanks!!!
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
The Following User Says Thank You to Moshpit37 For This Useful Post:
Mikepage (07-02-2014)
Old 07-02-2014, 04:55 PM   #48
Mikepage
Mikepage's Avatar
Do you love the new feeling?
o= FR-S =o
Old 07-02-2014, 05:08 PM   #49
Moshpit37
FR-S Owner!
Moshpit37's Avatar
I'm stuck on an Air Base for a couple more hours (Speed limit 30)... I'll let you know once I have a chance to really drive it.
Owner's Journal
Old 07-11-2014, 10:45 PM   #50
Mikepage
Mikepage's Avatar
Then who do you love the ride now?
o= FR-S =o
Old 02-17-2015, 10:41 PM   #51
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Just did this install tonight.
I also had strange salt water build up on the passenger side front bolt. I live in California so the car's never seen an ounce of road salt. Weird. Got my car December 2012.
I really appreciate the walk through, it was very helpful, particularly with the vague directions from Whiteline.
Only problem I had was threading the rear bolts in, but adjusting my jack a bit up and down took care of that.
Thanks!
YouShallKnow is offline   Reply With Quote
The Following User Says Thank You to YouShallKnow For This Useful Post:
Mikepage (02-17-2015)
Old 02-17-2015, 10:44 PM   #52
Mikepage
Mikepage's Avatar
Thanks!
Am sure you will love the new feeling and yes rear subframes bolts are tricky...
o= FR-S =o
Old 04-06-2015, 05:57 AM   #53
andrew5826
Seņor Member
andrew5826's Avatar
Drives: BRZ SWP
so does this guide differ when lifting the car up with the wheels off the ground?
andrew5826 is offline   Reply With Quote
Old 06-26-2015, 06:34 PM   #54
philooo
Drives: 13' Scion FRS Track car
thanks for the post, it was very helpful making it is less scary
It is actually quite simple.
One important thing though, because of my Tarmac2 suspension I actually had to remove the lower strut bolt, if not the subframe was not coming down more than a 1/4 inch. The suspension strut keep the assembly pushed up.
Once I removed the lower strut bolt, I was able to lower everything easily.
Also I had to unscrew all bolts a little: rear subframe, front rear submarine and also differential bolt, if not everything was to tight and even without any jack support and with the two most rear screw removed, the subframe would only drop a 1/4 inch.
I suppose my bushing were all in super tight shape
Car is only 12,000 miles.
anyways, very easy to install after all. I only wish whittling included more grease, one pack was really the strict minimum ! ideally use your own grease and put as much as you need to.
philooo is offline   Reply With Quote
Old 07-13-2016, 01:48 AM   #55
j_motion
Drives: 14 BRZ Red premium
Do you need an alighment after installing the insert ?
Ive noticed the hole for the bushing is not round is oval.
I when i was reinstall the bolt back in, i have to push the the subfram a bit to get the hole to light up before bolting back the back in.
So this might have shifted the subframe a bit.
or is this too minuscule to throw the alighment off ?
j_motion is offline   Reply With Quote
Old 11-09-2016, 01:05 PM   #56
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
extra grease in case anyone is interested
http://www.ebay.com/itm/171386890790
neilvosko is offline   Reply With Quote
bushing, crossmember, diy, whiteline
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Installed the Whiteline crossmember bushing(no pics sorry) gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-26-2013 02:00 PM
++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ genometuning Transmission and Driveline 4 10-12-2012 09:23 PM
