Software Tuning Discuss all software tuning topics. |
05-16-2020, 07:19 PM | #1 |
Drives: turbo frs
p0030 issue A01I
Dear all
I have install aftermarket header for someone 2014 auto FRs. ... ZA1JA01I After few minutes engine light came P0030 I have tune it stage 2 with Ecuflash I disabled p0030 And all related o2 codes But still keep coming even the code disabled from the map What I can do It take around 10-15 to show up I return back to stock rom When I turn switch on immediately cel show up same p0030 Crouse control stop Sport mode disable Gear changed hardly even I but it to manual mode I have changed both O2 sensors but still same issue Any idea?? Thnx |
05-16-2020, 07:22 PM | #2 |
Rust bucket enthusiast
Find the definitions for B01 and see if it comes on. If it only comes on when you flash the car, it's something with the map
05-16-2020, 07:24 PM | #3 |
Drives: turbo frs
05-16-2020, 07:25 PM | #4 |
Drives: turbo frs
05-16-2020, 07:41 PM | #5 |
05-16-2020, 08:11 PM | #6 |
Drives: turbo frs
05-16-2020, 08:22 PM | #7 |
05-16-2020, 09:35 PM | #8 |
Drives: brz 2017 hksv2
either is a electric link fail on the connector, or you damaged the sensor while installing in header, they re pretty fragile
05-16-2020, 09:44 PM | #9 | |
Drives: turbo frs
Also I have returned to stock header With stock rom but still same issue This happened after installing aftermarket header and off stage 2 tune I return everything to stock but still same 😭 |
05-16-2020, 10:52 PM | #10 |
Drives: turbo frs
05-16-2020, 11:13 PM | #11 |
義理チョコ
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | solidsnake11 (05-16-2020), tomm.brz (05-17-2020) |
05-17-2020, 11:22 AM | #12 |
Drives: turbo frs
Thnx to all
It was 15amb fuses |
The Following User Says Thank You to gt7877 For This Useful Post: | DarkPira7e (05-17-2020) |
05-17-2020, 02:49 PM | #13 |
Drives: brz
"It aint got no gas in it" "ummhuh" I guess you guys are too young to get that. Its from a movie called "sling blade" Last edited by solidsnake11; 05-19-2020 at 08:35 AM. |
Similar Threads | ||||
Automatic Transmission issue- dealer is not recognizing the issue, please help! | Arrex | Issues | Warranty | Recalls / TSB | 36 | 06-03-2019 04:15 AM |
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? | darkbluemn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-05-2018 08:49 PM |
P0134 and P0030->P0031 | Howardwei | Software Tuning | 7 | 12-08-2013 02:39 PM |
CODE P0134 and P0030 | Howardwei | Issues | Warranty | Recalls / TSB | 2 | 11-06-2013 04:54 PM |
Cel issue | Z06tofrs | Issues | Warranty | Recalls / TSB | 2 | 08-27-2012 10:13 AM |
