Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
View Poll Results: Is our gearlever rattling?
Yes 39 84.78%
No 7 15.22%
Voters: 46. You may not vote on this poll
Old 07-24-2015, 05:14 PM   #15
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
The fix is really very easy. I've explained it to Barloworld Centurion so they should be able to help.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 07-25-2015, 01:26 AM   #16
DarrenFord
DarrenFord's Avatar
Drives: Toyota x86 GRT
Brilliant thanks!
DarrenFord is offline   Reply With Quote
Old 01-30-2020, 09:22 PM   #17
mkodama
86Drive Challenge
Drives: 2017 BRZ PP
Yes! This fixed the 4000RPM+ rattle/vibration!
-No tools needed
-Jack up the car so you can reach around underneath comfortably.
-Pull the shift linkage rubber boot carefully away from the shifter and slide it onto the gear selector shaft; lots of stretching needed but it can take it!
-Do whatever is needed to keep the washer from rattling. I just applied some thick silicone grease, and oriented the washer so the convex side was on the plastic bushing and concave side on the spring washer.
Maybe this issue has to do with how this conical washer is oriented?
For anyone interested in getting shims or alternative washers, I took some pictures and measurements while I was there. Last picture is linkage pin diameter than the washer fits over.
mkodama is offline   Reply With Quote
The Following 2 Users Say Thank You to mkodama For This Useful Post:
MJones_RB (10-19-2021), sav (01-30-2020)
Ferrari like gear lever ? mashal Scion FR-S / Toyota 86 GT86 General Forum 56 10-20-2015 02:03 AM
first gear rattle Raves614 Engine, Exhaust, Transmission 11 04-14-2015 10:39 PM
Found the source of a rattle, and fixed it! BRZnut Issues | Warranty | Recalls / TSB 10 05-08-2014 10:39 PM
Front KNocking Noie and Gear Lever rattle Naughty AFRICA 17 10-26-2013 02:56 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
