Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
04-07-2014, 12:35 PM | #85 |
Drives: 2013 silver FRS
I don't want to sound like a noob but what do you guys mean by double clutching? Just pumping the clutch twice then trying to engage the gear your going for? Never had to double clutch. Driven a ton of manuals.
Also since two weeks ago when I did the fluid swap and bushings, after she's warmed up the trans feels pretty smooth! |
04-07-2014, 01:33 PM | #86 | |
04-09-2014, 12:09 AM | #87 |
Yeah I don't do that haha. Never have in any manual.
Thankyou tho! |
04-12-2014, 12:03 PM | #88 |
Drives: Black FR-S MT
Update. I followed JP's advice and adjusted my clutch. I put about 1 1/4 turns on the adjuster (in small steps) and it's definitely better, although the shift problem hasn't gone away completely. Dealer assures me that Toyota/Aisin are still working on a fix and I'll get it as soon as it's available, but in the meantime the clutch adjustment along with the warmer weather make the car almost pleasant to drive. I may even stop calling it the "Black Pig" if I can get the rattles fixed as well.
Regarding fluids - others on this thread mentioned that they might try Amsoil. I had Amsoil in my trans for a while and it was a big improvement over the standard fluid, but won't cure the problem. Current fill is GM Synchro, which feels slightly better than the Amsoil at very low temps, but I think not as good as Amsoil when it gets warmer. Next up will be Motul 300, which I've heard is the best option so I'll give it a try. Side note. When I adjusted the clutch I found that there is a totally bonkers contraption on the LHD version of these cars which transfers the clutch pedal input over to the master cylinder which is mounted to the right of the throttle pedal. I guess the car was designed to be RHD. Low budget or what!? Thanks again JP! |
04-15-2014, 04:32 AM | #89 |
Just a dude
Drives: Scion FR-S 2013
I've had OEM, Motul 300, Redline MTL & Pentosin in tranny.
MTL & Pentosin both are great, smooth good shifting and no felt issues at all. Motul 300 didn't feel any better then stock in fact took a fair bit of more driving to feel half assed.
04-15-2014, 07:48 PM | #90 | |
I assume you used Pentosin MTF2 75W80? Jason |
04-15-2014, 07:51 PM | #91 |
Just a dude
Yes correct sorry for not being clear on that. I'm on Pentosin now and keeping it that way as it feels best overall for my climate and needs etc..after a lot of reading up and looking at UOAs etc I can not see any harm what so ever in using it.
Similar Threads | ||||
6 Speed Manual Transmission 11k Miles | JoeDrifter | Transmission and Driveline | 10 | 05-24-2014 02:15 AM |
FI Guys: Were you more excited when you bought your car, or when you bought boost? | husker741 | Forced Induction | 28 | 02-25-2014 03:57 PM |
The dreaded Automatic Transmission Feel | chiefshayan | Engine, Exhaust, Transmission | 100 | 01-02-2014 11:31 PM |
How many miles were in your FRS when you bought it? | Kzzy | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 12-09-2013 03:01 PM |
Brz just broke 1k miles, clutch begins to feel grindy | rourich | Northern California | 14 | 10-11-2013 04:16 PM |
