Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-12-2019, 05:19 PM | #1 |
Drives: 2015 Subaru BRZ
Differences between Rear Lower Control Arms (SPC vs SPL, etc.)
Hello very sorry if this has been asked before. Not sure why we can't search for words with 3 letters in the search considering half the aftermarket brands are only 3 letters abbreviated.
Anyways, I'm considering buying a set of coilovers and I'm assuming with a bit of a drop, I'll need new LCAs to adjust camber in the rear. Is there a difference between the LCAs out there? Will the SPL LCA work just as well as the SPL LCA? Thank you! |
03-12-2019, 05:31 PM | #2 |
Country Boy 4 Life
Have you looked at pics of each brand LCA? They are both functional. One is "aftermarket" looking (nice!) and the other is OEM (stock) looking.
IIRC, the SPL has more adjustment then the SPC. Yes, LCA are needed to dial in rear camber after lowering. I would suggest a bump steer kit too. like this... http://www.ft86club.com/forums/showthread.php?t=130715 If the coils you are getting have tophats with camber adjustment in the front; cool. If not, you will want camber bolts at a minimum, possibly camber plates. Pro Tip: Use google to search. Type in what you are looking for and then add "ft86club". It makes finding things easier.
I LIKE TIRES! |
03-12-2019, 05:49 PM | #3 | |
Drives: Subaru BRZ / Toyota 86 Experts
The Following User Says Thank You to CounterSpace Garage For This Useful Post: | Leonardo (03-12-2019) |
03-12-2019, 07:27 PM | #4 |
I go to maybe 3-8 track days a year, but I'm not sure whether I want to go with a budget single adjustable(Tien flex a, hks hypermax, ohlins r&t) or something in the double adjustable range(jrz or act) for the coils.
I honestly don't really care about looks but Im just wondering if the SPLs are really necessary with the additional adjustability. Sent from my iPhone using Tapatalk |
03-12-2019, 07:51 PM | #5 |
LMGTFY
Drives: 13 FRS, 91 Miata
How sticky of a tire are you planning to run?
What track/s? |
03-12-2019, 07:53 PM | #6 |
I run with 86DC so I'm using GT Radal SX-2 and tracks would be Thunder Hill, Button Willow, Laguna and Sonoma.
03-12-2019, 08:14 PM | #7 | |
Drives: '23 BRZ
LCAs are hugely overprescribed IMO. I would lower the car first and see what you get, bearing in mind that -2 degrees and even more is perfectly streetable camber. FWIW I'm 1.25" lowered at -2.5 degrees rear camber and zero rear toe with factory arms. No problem... |
The Following User Says Thank You to ZDan For This Useful Post: | wparsons (03-13-2019) |
03-12-2019, 09:08 PM | #8 | |
Drives: '13 FRS - STX
03-13-2019, 03:04 AM | #9 | |
The Following User Says Thank You to CounterSpace Garage For This Useful Post: | wparsons (03-13-2019) |
03-13-2019, 10:05 AM | #10 | |
Drives: '23 BRZ
I doubt many FT86s will have more than ~0.5 degrees rear camber difference left vs. right, which IMO is not that big a deal. Honestly I wouldn't bother with aftermarket LCAs if I had something like -2.2 on one side and -2.7 on the other, but as it turns out I'm at -2.4/-2.6, which is of course totally fine. |
03-13-2019, 02:15 PM | #11 |
I would recommend against using LCAs with exposed spherical bearings for anyone that drives on roads that are salted. I use Cusco LCAs on my own personal car because of the rubber booty that protects a high quality bearing. Exposed bearings would not last very long on a street driven car in this area and I'd have to replace the ends more than I'd like.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | wparsons (03-26-2019) |
03-13-2019, 02:24 PM | #12 |
JHerbert Racing
Drives: 2013 Scion FRS
I do 25+ track days a year. I have -2.5 degrees of camber with the SPC LCAs. I paint marked them when I installed them and they haven't budged. Don't waste ur money on the fancy ones.
The Following User Says Thank You to Takumi788 For This Useful Post: | rawbeanz (03-13-2019) |
03-13-2019, 02:28 PM | #13 | |
Sweet, thanks! I'm probably just going to use the SPC ones, I got a killer deal on a set. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to rawbeanz For This Useful Post: | Takumi788 (03-13-2019) |
03-26-2019, 02:53 AM | #14 |
Drives: FR-S Turbo
I'm wondering if CSG and RaceComp can offer any feedback on the Blox Racing rear lower control arms?
They seem VERY beefy and decently made. Probably not as light as an all-aluminum machined arm but also50-60% less $$$. |
Similar Threads | ||||
Need to buy: stock rear lower control arms/toe arms and intake elbow | CoolHandMoss | Want-To-Buy Requests | 6 | 07-12-2018 08:44 AM |
ISC rear lower control arms | DavidBob | Brakes, Suspension, Chassis | 13 | 03-30-2017 07:26 PM |
FS: ISC rear lower control arms | DavidBob | NY / NJ / CT / PA | 4 | 03-30-2017 05:55 PM |
Megan racing rear lower control arms , toe arms, rear traction arm | fcdrifter20 | Brakes, Suspension, Chassis | 11 | 01-03-2016 08:11 PM |
