Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
07-05-2012, 12:27 PM | #57 | |
That Guy
Drives: 2013 asphalt FRS MT
Btw, Subarugenuineparts.com has the 160's on for $5.75 each, or $38.88 for 6. |
07-05-2012, 03:56 PM | #58 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
The 160s are a taller, but narrower filter. Compare a Purolator L14459 to a L14610 to see the difference.
07-09-2012, 12:21 PM | #59 |
That Guy
I was at the dealer today, they also told me that the 160 has superseded the 130. I asked for a copy of the TSB, I was allowed to read it, but not copy it. There was only two mildly interesting pieces of info on it. First, exactly what Draco described, the filter dimensions are slightly different. Second, the 130 will not be superseded on two model years of the Forester but will be on everything else using a F series engine. Now, my question is, what's different about the Forester that the old filter has to be continued on those?
The more I think about this, the more I think I want to go with an aftermarket filter setup. I know someone has said that the Subaru filter has a higher bypass pressure. But that's just causing a higher differential pressure across the filter. Thus allowing the oil pressure to drop lower as the filter gets older, instead of using a filter that doesn't need that high of a differential to last through the service interval that the bean counters specified. |
Similar Threads | ||||
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? | Kostamojen | Engine, Exhaust, Transmission | 90 | 03-20-2022 06:05 PM |
FA20 OEM pistons, are they Forged or Cast ? | adprokid | Engine, Exhaust, Transmission | 54 | 10-11-2014 05:51 PM |
Turbocharged FA20 targeted for 270hp. Confirmed for next gen WRX | Hachiroku | Engine, Exhaust, Transmission | 50 | 12-10-2011 01:23 PM |
FA20 for sale | coyote | AUSTRALIA | 1 | 12-01-2011 12:53 AM |
