Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-31-2012, 12:02 AM | #29 |
Drives: 2006 Subaru
^^ unless the part that fails causes the damage.
Oil filter fails, Causes mains to fail. Subaru or Toyota will turn down your claim. And point you to the direction of the oil filter company. Sub/Toy part did not fail, The root of the failure is the oil filter. The damage is the main engine bearings. The rings in the motor fails. Then they do not care about a non oem oil filter. Anything oil related fails, They will point at the oil filter and turn your claim down. |
05-31-2012, 12:05 AM | #30 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
How exactly does an oil filter fail? Thats a pretty far-fetched instance.
05-31-2012, 12:11 AM | #31 | |
Drives: 2006 Subaru
It happens more then you think. Google Fram and oil filter failure. I have a fram fail. Took out a motor of mine. Went back to shop about it. Was told "yup sorry" they just asked us to pull those quietly. Here is their claim number. Never heard a word... |
05-31-2012, 12:13 AM | #32 |
Drives: 2006 Subaru
http://www.google.com/webhp?rlz=1C1S...w=1600&bih=717
Read away! knowledge is key! Don't be that guy with a blown motor and a bad oil filter. Last edited by TwinscrollGT35R; 05-31-2012 at 01:08 AM. |
05-31-2012, 12:22 AM | #33 |
Proud of FR Layout
I thought everyone knew fram was shit? Thats been a verified fact since I was in high school ffs.
NEXT. |
05-31-2012, 12:24 AM | #34 |
Proud of FR Layout
dbl post: You dont have to be a **** bag just because I just shut you down earlier. Show me a REAL oil filter that has failed.
If you run a fram 'filter' you deserve to blow up engines. |
05-31-2012, 12:54 AM | #35 | ||
Drives: 2006 Subaru
Fram is still an oil filter. search around and you will find more brands. Quote:
Don't blame me. I'm passing along real life events. Like I said. I am unsure why everyone hates on the OEM oil filter. I use them on my 550+whp 20k Cosworth motor. I am sure a FA motor will have no problems using the same filter. Its also not worth going into how the oil filter works with the oil pump. You will all figure it out in the long run. There are people that have, And there is people that will. Only you can pick which side you are going to be on. |
05-31-2012, 12:59 AM | #36 | |
Proud of FR Layout
Ill just quote myself here and leave it be. Im not sure you were replying to me since I have never cited any sources aside from the FTC, Id certainly never take anything said by K&N as fact. |
05-31-2012, 01:30 AM | #37 | ||
Drives: 350z Nismo, CBR1000RR
I don't think anybody said anything bad about the OEM Tokyo Roki filters, just the mediocre Subaru ones. Subaru already did get the cheapest filter they could that's where the whole discussion began (cost-cutting to increase gross margins will always come into play, as businesses exist to make money). If an oil filter is the direct cause for catastrophic engine failure and that can be proven, then obviously it's a legitimate claim to deny a warranty. However, you'd be surprised at how many incidents that you would think would invalidate warranty claims actually don't in the real world. Bottom line is, don't buy FRAM, stick to OEM or one of the more proven aftermarket brands. |
06-06-2012, 04:37 PM | #38 |
Drives: WRX
For what its worth,
nasioc's conclusion over the years is that on our EJs, OEM subaru oil filters are best for our engines. Not sure if this crosses over into the world of the FA20, but its still a boxer motor. Personally, I'm glad I'm getting mine at the end of the year, I'm sure by then someone who frequents bob the oil guy will have figured something out |
06-06-2012, 04:39 PM | #39 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
FWIW, buy from Subaru and not Toyota. At least in Norcal Toyota dealers don't seem to have them in stock, and also said list price was $22! I picked up 2 from Subaru for $8 each.
The Following User Says Thank You to finch1750 For This Useful Post: | Gannicus77 (07-08-2012) |
06-06-2012, 07:38 PM | #40 |
Drives: '13 BRZ TLM Spec
Note: The BRZ can use either the 15208AA130 filter or the 15208AA160 filter from Subaru, both are made by Tokyo Roki and use the same pressure bypass. The difference is their overall size (The 130 is a little larger than the 160).
06-07-2012, 12:26 PM | #41 |
Drives: Whiteout FR-S
How do you find out the pressure or check valves for other filters?
I planned on using Royal Purples oil and filter. Now I'm questioning it. Their filters are usually indestructible, and I thought used much higher pressure. Google isn't helping today :/ |
06-08-2012, 01:14 AM | #42 |
That guy
Drives: Ultramarine mt FR-S
http://www.subaruonlineparts.com/pro...oducts_id=1309
Oil filters + crush gasket at $6.44 per. The 12 pack only breaks down to 6.03 per. Last edited by Hawaiian; 06-08-2012 at 09:53 AM. |
The Following 5 Users Say Thank You to Hawaiian For This Useful Post: | BadCompany235 (06-25-2012), Fly Guy (06-08-2012), hyper4mance (06-11-2012), Laika (06-08-2012), phm14 (06-16-2012) |
Similar Threads | ||||
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? | Kostamojen | Engine, Exhaust, Transmission | 90 | 03-20-2022 06:05 PM |
FA20 OEM pistons, are they Forged or Cast ? | adprokid | Engine, Exhaust, Transmission | 54 | 10-11-2014 05:51 PM |
Turbocharged FA20 targeted for 270hp. Confirmed for next gen WRX | Hachiroku | Engine, Exhaust, Transmission | 50 | 12-10-2011 01:23 PM |
FA20 for sale | coyote | AUSTRALIA | 1 | 12-01-2011 12:53 AM |
