Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-02-2020, 09:04 AM | #15 |
Identifying as a Member
Drives: 2013 FRS LS1
Nice, write up... Sub'd to remember which ones to buy... lol
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline |
The Following User Says Thank You to Tomm For This Useful Post: | therealstoly (12-02-2020) |
12-02-2020, 11:14 AM | #16 |
Drives: '23 BRZ
0.02c:
I'da spent some of that $$$ on better damping! Really impressed with Bilsteins vs. stock PP/Sachs As a structural engineer, I'd say that for sure these braces will locally increase stiffness. But I'd like to know how much they increase the overall stiffness of the chassis. Not practical but would be great to see N-m/degree for stock vs. addition of braces. For my car, I've never felt like it needed additional chassis bracing. I did install the Whiteline rear subframe stiffeners though, which seemed to settle the rear end a bit in rapid transitions. |
The Following User Says Thank You to ZDan For This Useful Post: | therealstoly (12-02-2020) |
12-02-2020, 01:27 PM | #17 | |
Drives: 2017 Toyota 86 (860 SE)
The Following User Says Thank You to Cephas For This Useful Post: | therealstoly (12-02-2020) |
12-02-2020, 03:25 PM | #18 |
Drives: '23 BRZ
I was initially fine with the factory dampers, though over the years/miles I got tired of the high-speed compression damping that IMO makes it *feel* a bit more sporty/go-karty initially. Ultimately factory PP/Sachs struts didn't have enough bump travel for me, lowered 1.25" with springs and with camberplates that took another ~0.75" of bump travel. Every bump I'd bottom out the front suspension, BAM! Bilsteins are a lot smooother in terms of high-speed compression damping, while also having more low-speed damping for control, especially with stiffer springs. And they have a ton more bump travel, no problems with bottoming out the fronts now! Love it...
12-02-2020, 04:21 PM | #19 | |
Weight Weenie
Drives: 15 FR-S
You'd like the rear subframe inserts from whiteine. It settles that feeling you're describing. |
The Following 3 Users Say Thank You to new2subaru For This Useful Post: |
12-02-2020, 09:07 PM | #20 |
Drives: 2020 BRZ Limited
The Sachs/Eibach set-up has always been a band-aid to hold me over as I researched/learned this platform and unlearned the Miata. Found the XIDA from 949Racing to be the best I ever had with a Miata and am watching (along with everyone else) their development for this platform. I've also talked with RCE about the Tarmac 2. I think I've whittled it down to about three options and I hope to have new coilovers in the next month or two. Haven't been in a huge rush as I didn't want to swap suspension before I finished the Cusco experiment.
The Following User Says Thank You to therealstoly For This Useful Post: | ZDan (12-02-2020) |
12-02-2020, 09:15 PM | #21 |
12-02-2020, 11:39 PM | #22 |
Drives: JRSC BRZ SOLD
Interestingly Motoiq.com used the same Cusco braces on their Project FRS and had much the same impression as you have with them! I'm am very much interested in the front cross member brace and rear member sides, but IDK if they would be compatible with the MCA traction mod bracket I run. Only one way to find out.. I plan to devote more mods to suspension in the new year including 949 Racing's coilovers when they come out.
The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post: | Ohio Enthusiast (12-03-2020), therealstoly (12-03-2020) |
12-03-2020, 01:34 AM | #23 |
Drives: 86
Bravo , this read like a novel.
I wasn't going to invest in bracing, but now you've got me curious |
The Following User Says Thank You to Celica00 For This Useful Post: | therealstoly (12-03-2020) |
12-03-2020, 08:25 AM | #24 | |
Thanks so much for those! Cusco owes you some commission on future sales, I think. |
The Following User Says Thank You to Cephas For This Useful Post: | therealstoly (12-03-2020) |
12-03-2020, 10:05 AM | #25 |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | therealstoly (12-04-2020) |
12-03-2020, 10:17 AM | #26 |
That plaid is pretty dope, not gonna lie!
12-03-2020, 10:47 AM | #27 |
I'm a sucker for plaid, so that's pretty cool.
Cusco at least used to make front lower control arm braces that did not have the cross bar. Haven't seen this one. Neat. I think some of the function of the 2 rear braces you really liked would be similar to the Whiteline subframe bushings (or bushing inserts). I need to have a closer look at the rear side braces though. More weight with the braces vs bushing inserts, but easier to install (and uninstall). The inserts are still pretty easy to install. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | therealstoly (12-03-2020) |
12-03-2020, 12:47 PM | #28 |
Drives: 2014 Subaru BRZ Limited MTblue
hey therealstoly,
Thanks! Now I can name you a culprit regarding my purchasing! |
The Following User Says Thank You to snuff58 For This Useful Post: | therealstoly (12-03-2020) |
Similar Threads | ||||
TB Performance Bracing Review | Zach3794 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 11-11-2013 09:23 PM |
Cusco: Toyota 86 / Subaru BRZ Suspension & Bracing !! | Speed Element | Brakes, Suspension, Chassis | 42 | 06-14-2013 02:20 PM |
CUSCO Chassis Bracing & Suspension IN STOCK Free Shipping LOWEST PRICES on FT86Club!! | CygnusPerformance.com | Brakes, Suspension, Chassis | 27 | 05-16-2013 07:06 AM |
Cusco And Beatrush - The All Japan Strut Bracing Thread! | RallySport Direct | Brakes, Suspension, Chassis | 1 | 02-12-2013 05:47 PM |
TB Performance Chasis Bracing Review | xclusive_brett | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-05-2013 10:46 AM |
