Old 12-19-2023, 03:44 PM   #15
gpvecchi
gpvecchi's Avatar
Regarding the Subaru/Toyota configuration for A/C, you need even the matching A/C panel, different part numbers with different software.
Anyway, the only difference is the display; Subaru Full Auto=Toyota Auto, Subaru Auto=Toyota manual, the behaviour is exactly the same.
Old 12-25-2023, 10:54 PM   #16
Compelica
Compelica's Avatar
Drives: 86 GT
IIRC I can change to the Subaru/Toyota behavior without needing a panel change... or did I understand you correctly?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 12-27-2023, 12:50 AM   #17
gpvecchi
gpvecchi's Avatar
No, you need to change the A/C panel too, or it will not work correctly.
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 04:01 PM
Toyota Techstream Confusion geruta Engine, Exhaust, Transmission 12 04-06-2016 10:36 AM
Toyota Techstream OBD-II USB Cable FRSBRZGT86FAN Engine, Exhaust, Bolt-Ons 1 02-24-2016 11:06 PM
Toyota TIS techstream V10.10.018 kiki2015 Scion FR-S / Toyota 86 GT86 General Forum 0 07-17-2015 10:11 PM
Toyota Techstream on BRZ? pinoy_dorifto Engine, Exhaust, Transmission 6 05-15-2013 11:56 AM
