06-13-2017, 04:32 PM | #3263 |
Drives: 2017 WRB Subaru BRZ
Since January watching the IMSA Datona 24hrs, and the news at that event that Continental was working with many championship winning drivers to develop their new Continental Extreme Contact Sport tire, I have been looking for and reading every testing article I can find on them like these two below which put them up favorably against the existing MPSS. Tires make a huge difference in how close to your ideal car usage goals you can get, and I was considering stepping back from the category of RE 71R, Rival S 1.5, and above mentioned Hankook, and into something like the CECS. This would dial me back to better streetable performance and less trackable performance, but still having enough performance to be used on the track on occasion. What do you think about these? Have you tested-heard of anyone's experience with these tires? http://blog.caranddriver.com/its-ext...contact-sport/ http://www.motoiq.com/MagazineArticl...act-Sport.aspx |
The Following User Says Thank You to SStratos For This Useful Post: | Racecomp Engineering (06-13-2017) |
06-13-2017, 05:48 PM | #3264 | |
- Andrew |
06-13-2017, 06:13 PM | #3265 |
Drives: 2015 Raven FRS
Take a look at Falken's new 615K+. I have 2 track days on a set and love them. Much more grip than my old Hancook RS3. Even though they are a 200 tread wear they feel as good as my Nitto NT01's felt.
06-13-2017, 06:45 PM | #3266 | |
Drives: FR-S Whiteout
I tested a friends ND using these tires, who typically run the Michelins on his car. Performance is comparable but inferior to the PSS in the dry. Treadblocks seem to be taller on the conti's and it seems to translate to more road noise and feels squirmy. Supposedly very good in the wet, but I wouldnt know firsthand. Only driven in the dry.
Intent > Content
cowardice is the mother of cruelty. |
The Following User Says Thank You to solidONE For This Useful Post: | SStratos (06-16-2017) |
06-13-2017, 09:08 PM | #3267 |
Drives: Subaru BRZ
Body roll and lifting a wheel
Hi all,
Considering stiffening up my suspension for weekend hillclimbs/sprints with an entry level spring and swaybar package. Just wondering if anyone has experienced lifting a wheel as a result of stiffer suspension. I'm thinking with such a low CG its unlikely. |
06-13-2017, 09:42 PM | #3268 | |
If the course has any curbs you clip you can lift a wheel on a totally stock car (how the pedal dance mode was discovered to be useful). |
06-14-2017, 01:18 AM | #3269 |
Drives: Subaru BRZ
I run medium compound AO50s. They're pretty sticky. What I'd read was that a stiffer rollbar will be more inclined to lift the inside tyre, but I think this is assuming the spring rate stays the same. I get that stiffer springs will reduce roll, and a company that produces packages like this would know what they're doing.
Suspension setup seems like more art than science. |
The Following User Says Thank You to Purist For This Useful Post: | strat61caster (06-14-2017) |
06-14-2017, 10:44 AM | #3270 | |
I wouldn't let lifting a wheel stop you from increasing your roll stiffness...you do need it with those sticky tires. Stiffer swaybars are the cheap and easy "solution" but they do have their drawbacks. You would still be faster with stiffer bars, but coilovers would really be the way to go (possibly in addition to stiffer bars). - Andrew |
06-14-2017, 07:07 PM | #3271 |
I have Tein Flex A coil overs with swift 10K springs, 200 tread wear Falken 615K+ tires. Would stiffer sway bars reduce my lap times?
06-14-2017, 09:23 PM | #3272 |
Drives: 2017 BRZ
The Following User Says Thank You to cjd For This Useful Post: | strat61caster (06-14-2017) |
06-15-2017, 06:15 PM | #3273 | |
Drives: 2013 BRZ automatic
Caster, Camber & Tie Rods
With OE springs, top mounts have a limited range of adjustment-especially if you want a meaningful caster increase (2+ degrees). And you raise the front of the car. RacerX adjustable LCA's with urethane bushings looked like the answer for me, but they no longer offer urethane. Spherical rod ends only, with recommended annual replacement. A custom-built LCA is too pricey, but moving the trailing LCA pivot point looks relatively simple. It will get me the camber I want, but admittedly will only give me about a 1/3 of the caster increase I was looking for. It should still be feasible to add an offset to the front pivot point (WL or other) to gain another small bit of caster, however. So, back to my original question--does anyone know a way to get increased tie rod length, without spherical rod ends? |
06-15-2017, 06:36 PM | #3274 | |
When adding that much caster be careful, you may start overheating the power steering unit and loosing assist mid-corner. Edit: for the steering rods, maybe WRX's are sized longer? Last edited by strat61caster; 06-15-2017 at 06:52 PM. |
06-15-2017, 06:55 PM | #3275 | |
Drives: 2013 Subaru BRZ
There's only so much grip available. Whether that grip causes a lot of body roll or a little doesn't matter much. Roll control is about keeping the wheels upright, I.e. At the camber angle you decide you need, for as much of the suspension travel as you have. Shorter and stiffer springs reduce the camber change by reducing body roll. They also reduce the CG but, seriously the BRZ starts at 18 in CG height so dropping even two inches in ride height isn't making much difference. The main effect of shorter stiffer springs is reducing camber change. |
06-15-2017, 06:58 PM | #3276 | |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
