Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
09-28-2019, 09:35 AM | #15 |
What flywheel do you have? Also try turning off the A/C when it rattles to see if that fixes it.
10-04-2019, 08:36 AM | #16 |
Drives: frs
10-04-2019, 10:38 AM | #17 |
12-04-2021, 12:41 AM | #18 |
Drives: BRZ S
You ever figured out what it is? I notice it only happens when cold. After awhile it goes away.
05-24-2022, 02:11 PM | #19 | |
Drives: 2016 scion frs
05-24-2022, 02:38 PM | #20 |
義理チョコ
That bit of sideward play is fine. Is that your transmission knocking in the second clip? Does it go away when you tap the clutch pedal a bit, or do you have to completely disengage?
05-24-2022, 03:16 PM | #21 |
Yes, i think my transmission is rattling/knocking and it only goes away when i fully press in the clutch
https://youtube.com/shorts/aRhbkgfNqf8?feature=share |
05-24-2022, 04:00 PM | #22 | |
義理チョコ
05-24-2022, 04:34 PM | #23 |
Ahh poo. The noise is becomes really bad when the ac clutch kicks on. Maybe thats what i get for using a not brand new TOB. I know the TOB installed was around 10k miles old, it was the updated(white dot) one. Welp, trans getting pulled again. 😭
05-24-2022, 04:44 PM | #24 |
義理チョコ
Now hang on. Did you confirm by just pushing the clutch pedal partially? Post a video of you pushing it only a third of the way down, just some so there's pressure on the TOB but the transmission keeps spinning.
The Following User Says Thank You to Ultramaroon For This Useful Post: | jrhudson (05-25-2022) |
05-25-2022, 01:06 AM | #25 | |
i forgot to mention, i think my TOB is loose or the clips are loose or off. I reused some old ones like 55k miles old clips but i bent them to shape. maybe stressed them out too much? |
05-25-2022, 01:30 PM | #26 |
05-25-2022, 02:04 PM | #27 |
義理チョコ
I take back the TOB call. Does the transmission whine when driving? That's a pretty loud rattle.
05-25-2022, 02:41 PM | #28 |
It might be the TOB still since the car is warmed up and i dont really hear it and/or its not as bad. I suspect it the retainer clips, its probably barely holding onto the TOB. I only drove around for a short time but there wasn’t any whining or weird noises.
Similar Threads | ||||
Transmission Noise in Neutral @ Cold Start | Jackal84 | Issues | Warranty | Recalls / TSB | 57 | 03-01-2021 03:21 PM |
FRS Rattle when clutch engaged in neutral | savioita | Issues | Warranty | Recalls / TSB | 20 | 11-26-2017 04:00 AM |
cluck cluck clutch rattle in neutral to engagement??? | Packofcrows | Issues | Warranty | Recalls / TSB | 32 | 11-14-2015 11:28 PM |
Car rattle at neutral. | IloveBaldEagles | Issues | Warranty | Recalls / TSB | 3 | 12-23-2012 06:55 PM |
Weird rattle when put into neutral | SleekMachine | Issues | Warranty | Recalls / TSB | 1 | 10-18-2012 10:25 AM |
