#85 |
Marked a reference to this thread. I really don't have any hit of understeer. Granted, I have Aero, Stiffer Front bar, stock newer Rear bar(bit stiffer that the early 13-16 OEM bar) and now 4 point roll cage welded in. This Mofo sticks to the track with my T2's and 7K square
2013 Series 10 FRS #553
#86 |
Drives:
Ended up driving it finally.
The entry now has a touch of oversteer. But mid corner and exit we cleaned it up and now it’s borderline neutral. Felt a lot better than the 7k square setup. Sent from my iPhone using Tapatalk |
#87 |
Drives: 2017 BRZ series.yellow
Glad you are liking the setup better.
Your turn in inputs seem a bit aggressive. Looks like in many spots you are hammering the wheel over very hard and fast and then have to bounce back a bit and find stability. |
#88 | |
Drives:
Yeah my steering wheel action needs adjustment. You’ll see if you watch my videos it’s my biggest weak point. Sent from my iPhone using Tapatalk |
#89 |
Drives:
New drive this week:
#90 |
Drives:
#91 |
Looks like this set up is working better for you now which is good to see. Spring rates are important but it always bothers me when someone claims to have 1 magic formula for everyone and every application. Many other variables to consider.
- Andrew |
#92 | |
Drives:
If only there was one magical formula! Either way, yes, it all ended up heading in a better direction for my use case! Sent from my iPhone using Tapatalk |
| Understeer on '22 BRZ | Fletch | Tracking / Autocross / HPDE / Drifting | 29 | 12-20-2022 09:09 PM |
| oversteer and understeer | orc | BRZ Second-Gen (2022+) — General Topics | 76 | 10-05-2021 03:08 PM |
| Why does car understeer when going downhill? | hpde_addict | Tracking / Autocross / HPDE / Drifting | 20 | 01-15-2018 09:42 AM |
| Understeer after new wheels | carsebuco | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 12-04-2017 05:49 PM |
| understeer on 17 brz | alex.s | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 37 | 09-11-2017 04:05 AM |
