Software Tuning Discuss all software tuning topics. |
09-09-2022, 12:09 PM | #1 |
Drives: 2013 FRS GTX3076R
Ecutek racerom electronic boost control tuning.
Hello,
So I've recently turbocharged my frs, have it tuned on a manual boost controller right now and it's running reasonably well. I'm trying to setup an ebc right now but the ecutek tuning guides i've found are for the older versions of racerom where they use multiple custom maps to setup boost control. Can anyone point me in the right direction for the current racerom where boost control is integrated into racerom? Thanks. Sent from my SM-G991W using Tapatalk |
09-09-2022, 12:31 PM | #2 |
Rust bucket enthusiast
What rom revision are you using? I recall having a hard time finding it from B01C but it showed up under A01C.
Make sure you have the Racerom patch applied to the car as well. "Boost Target" is where I'd start looking
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
09-09-2022, 02:01 PM | #3 |
Thanks for the reply, I'm using a01c. I have found the boost control maps already. I'm trying to setup an open loop boost control, do you know which values to zero out on the proportional and integral settings to disable closed loop? Thanks.
09-09-2022, 02:23 PM | #4 |
I am not in a position to provide tuning advice. There may be others on here that will provide more guidance, sorry.
09-09-2022, 03:49 PM | #5 |
All good, thanks.
09-11-2022, 06:46 AM | #6 |
Drives: WRB BRZ
09-23-2022, 04:58 PM | #7 | |
Similar Threads | ||||
EcuTek Programming Kit + RaceROM Tuning Upgrade | Kodename47 | Audio/Visual, Electronics, Infotainment, NAV | 4 | 12-06-2020 07:07 PM |
FRS/BRZ ELECTRONIC BOOST CONTROL | 671mike | Forced Induction | 6 | 06-05-2018 06:07 PM |
electronic boost control. | Jaden | Forced Induction | 10 | 02-02-2015 11:28 AM |
Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
