Old 04-03-2015, 08:28 PM   #1
awhatzable
Drives: GTS86
Does this Chip & thin dent require sanding before touchup ?
The thin dent circled in red is less than 1mm deep and the chip is 2mm in diameter.
awhatzable is offline   Reply With Quote
Old 04-03-2015, 08:33 PM   #2
shellslinger
Drives: Whiteout FRS
I would not sand. IMO, just get the touch up paint, fill it in w/ paint then use Langka Blob remover to finish flush with the rest of the body.
shellslinger is offline   Reply With Quote
The Following 2 Users Say Thank You to shellslinger For This Useful Post:
hmong337 (04-03-2015), Tcoat (04-03-2015)
Old 04-03-2015, 08:45 PM   #3
awhatzable
Drives: GTS86
Should I use the langka blob after or before the finishing clear coat ?
Old 04-03-2015, 09:24 PM   #4
civdaddy
Drives: Slow
Dab of touch up paint and call it a day.
civdaddy is offline   Reply With Quote
Old 04-03-2015, 09:50 PM   #5
awhatzable
Drives: GTS86
So just the touch up paint is enough to fill up the light dent nicely ?
Also can I just use clear coat to fix the dent up or do I need the base + pearl ?
Old 04-03-2015, 11:22 PM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
For pearl white paint (which is a pain), add a layer of base paint, let it dry, add a layer of base paint, let it dry (over and over again until it's about the same height with the body), and then apply ONE coat of the pearl. If you add multiple layers of the pearl, it becomes dark.
N1rve
Old 04-03-2015, 11:38 PM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I would sand it a bit just in case unless you are sure there isn't any rust build up… Glue some sand paper on the tip of a pencil where the eraser is, and just give it a few rubs only on the metal. I've had similar chips in my fender wells.
Instagram: stimson
Old 04-04-2015, 03:56 AM   #8
awhatzable
Drives: GTS86
Haven't tried but, what should I do if I see rust after rubbing down a bit ?
I've been using a blob of vase line to keep moisture out lol I don't know if it works though.
Old 04-04-2015, 04:28 AM   #9
shellslinger
Yeah, so just clean out the chip w/ soap or rubbing alcohol then apply the touch up paint then use langka blob remover. No need for clear coat, just use base + pearl. It won't match 100% but it'll sit flush with the car and no one but you will ever will notice.
Old 04-04-2015, 04:11 PM   #10
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
If it's not peeling, I would not wet sand. I'd clean with rubbing alcohol, touch up, then wax. Put 2-3 coats of wax on that panel/side...etc Don't do 3 waxes in one day, leave like 4 days in between for that spot if it's deep.
...or long way, bondo? It's just a precaution i'd take so it won't rust in future.
I'm overdoing it, ain't I?
Old 04-04-2015, 04:38 PM   #11
Chanpion
Drives: 13 FRS Satin
Sand it first, reason being, you could miss any startup of rust or trap dirt in it.
Chanpion is offline   Reply With Quote
Old 04-04-2015, 08:28 PM   #12
iarefluffy
iarefluffy's Avatar
Drives: CWP series blue brz
when you say pearl, is it the crystal white pearl? like the color they have for the 2015 white brz's?
iarefluffy is offline   Reply With Quote
Old 04-05-2015, 05:13 AM   #13
awhatzable
Drives: GTS86
It 2013 37j Pegasus White Pearl
Guys i dont know if its clear coat chip or paint chip.. HELP BRZ_Kamil Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-19-2014 10:23 PM
Hair-thin scratches !!! Pish Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 05-13-2014 10:31 PM
Painting tails red. Is it worth wet-sanding/clear coating? nodeal Cosmetic Modification (Interior/Exterior/Lighting) 25 04-01-2014 05:17 PM
Wet sanding curves qoncept Cosmetic Modification (Interior/Exterior/Lighting) 3 07-02-2013 02:50 PM
Ding/Chip/Dent Repair in Seattle Area Vukodlac Northwest 5 04-28-2013 06:04 PM
