Software Tuning Discuss all software tuning topics. |
05-17-2020, 06:33 PM | #15 |
Drives: TRD R.S. 1.0 FRS
a
05-17-2020, 07:30 PM | #16 |
Drives: JRSC BRZ SOLD
05-17-2020, 10:17 PM | #17 |
Drives: 2017 toyota 86
It’s more like 5 hp. And no. The 5hp gain is from new intake manifold, header and corresponding tune. Although primarily header/tune especially for peak hp. Which Your replacing both. So same end numbers just slightly different before numbers, with pre 17s benefiting 5hp more.
05-18-2020, 01:24 AM | #18 |
Drives: SWP BRZ
JDL 4-1 dyno sheet for reference
This is after Zach tuned my car at The Racer's Line. JDL 4-1 EL header, stock front & mid pipes, Nameless axleback. Red = E85 tune. Blue = 91 tune. Green = stock.
The Following 2 Users Say Thank You to PandaBRZ For This Useful Post: | DarkSunrise (05-18-2020), solidONE (05-19-2020) |
05-18-2020, 01:24 AM | #19 |
Drives: 2014 GT86
There is also a bit of MY2017 airfilter being less resistive .. then again, aftermarket drop-in airfilter for prerestyle is relatively cheap and most probably also will be in mod list for those that tune their ecu, removing that difference too.
05-18-2020, 07:58 AM | #20 | |
TRACKBREAD
It’s more in the 10-15 hp range. 2017 dynos show a bigger difference than the spec sheets suggests: EDIT: No it isn't! Thanks @86TOYO2k17 for clearing that up! https://www.ft86club.com/forums/show....php?p=2775136 Last edited by Yoshoobaroo; 05-18-2020 at 11:49 AM. |
05-18-2020, 10:23 AM | #21 | |
+5whp which is whats to be expected as its advertised as making 5 more hp from the changes made to post 17s. also another good comparison here, same day, same dyno, same gas. less than a 5hp difference. scroll down to 2013 MY vs. 2017 MY https://www.pointmeby.com/2017/10/18...esults-15-86s/ The few cherry picked ones showing 10-15whp probably had the dyno set to 4.1 FD instead of 4.3FD for the 17+ artificially showing higher number. Or where done with different correction factors, temps, humidity etc... on different days or comparing a new fresh low mileage 17+ to a pre 17 with high mileage or a heavily beaten on track car that's losing compression etc... making it look lower. or the 17 had 93 and the pre 17 had bad gas or 91. There is no reason the drive train loss would be greater on a pre 17, and i highly doubt Toyota/Subaru is under selling the HP of post 17s by 10+hp. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Yoshoobaroo (05-18-2020) |
05-18-2020, 02:51 PM | #22 |
Good Job Subaru!
Drives: Green '17 BRZ Sport-Tech MT
I got it installed at the shop that it was tuned at, so I never drove the JDL 4-2-1 on the stock tune. Main basis of comparison I had was stock header and tune vs. JDL and Dyno tune, and man, what a transformation.
The Following User Says Thank You to JBezugs For This Useful Post: | CSG Mike (05-18-2020) |
05-18-2020, 03:08 PM | #23 | |
Good Job Subaru!
The primary takeaway is that the header and factory tune was the main difference in power output between pre-and-post-facelift cars, albeit a minor one. There were other engine changes, but they were primarily related to strength and robustness. However, as soon as you change out the header and go with a custom tune, the gain between pre-and-post facelift cars is essential moot, because you've replaced those components. An aftermarket header and quality tune is the equalizer if you will. You will see larger gains on pre-facelift cars due to the older header design and more conservative stock tune, but your final numbers between engines should be similar. Let's negate any minor gains in the post-facelift intake design which I don't think really makes a huge difference (for what its worth I'm running an OEM paper filter on my +17 but I'm sure with an aftermarket filter on an older car you'd be right there with me). With that, basically, on the same dyno, on the same day, a 2013-2016 car with a custom tune and "Aftermarket Header A" should make very similar if not the same power as a 2017+ car with a custom tune and the same "Aftermarket Header A".
05-18-2020, 05:42 PM | #24 | |
- the JDL 4-1 EL header made 209 whp - the JDL 4-2-1 EL header made 195 whp The shape of the torque curves are pretty similar, but the 4-1 EL header seems to hold power higher in the RPM range.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | PandaBRZ (05-19-2020) |
05-18-2020, 05:45 PM | #25 | |
05-18-2020, 06:59 PM | #26 | |
Drives: 2017 86 860 Special Edition
05-18-2020, 07:13 PM | #27 |
Yeah you could be right. I saw that he was on E55. MBT on the FA20 is reached at ~E60, so he was ever so close on that tank. That probably explains some of the difference.
05-19-2020, 01:01 PM | #28 | |
Drives: FR-S Whiteout
Such a worthwhile mod.
Intent > Content
cowardice is the mother of cruelty. |
Similar Threads | ||||
Dyno Results - OFT Stage 2 UEL + Openflash Header + Full Exhaust | pinski | Software Tuning | 8 | 11-21-2016 11:07 AM |
My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 04:09 PM |
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results | JDM-dono | Engine, Exhaust, Transmission | 24 | 05-05-2016 04:54 PM |
Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
