07-25-2021, 11:46 PM | #127 |
Howdy
Drives: 2020 BRZ PP
Awesome log! Just read all 9 pages. I hope you can still find time to tinker on it; I appreciate all your advices around here.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
The Following User Says Thank You to BrahmaBull1990 For This Useful Post: | DarkPira7e (08-10-2021) |
08-10-2021, 12:36 PM | #128 |
Rust bucket enthusiast
Just dropping in to let everyone know I didn't die!
I got the heads all together, bolted on, valve covers on. I took the cam gears apart to clean everything and am happy I did- one of them had the floppy door that leads to replacement of the gear anyway! So, purchased a new gear and things are good. The reason that the floppy door is bad, is that it has a spring behind it that, in tandom with the door, controls oil pressure for cam timing. If the door is FLOPPY, it doesn't hold the correct oil pressure!!! I don't have a good photo of it, sorry. I have included a bunch of photos of the cam gear innards, in case you were curious how complex these things are. I have also included a photo of the oil filter screens you need to replace. I ended up getting an AEM 340lph pump and putting it in. Had to purchase all new rockers, shims, caps, valve stems, tons of misc bolts. Toyota threw away almost all of that stuff, and my old engine is still in the car. Put all new rotors and pads on the car, as well as making a custom gauge pod in the instrument cluster bezel. I just cut a hole in it and behind it, fits perfectly. Photos are in no order- car now sits at VEMS awaiting the old engine to be fully removed and then we'll begin final assembly!
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
The Following User Says Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (08-10-2021) |
08-10-2021, 01:50 PM | #129 |
Drives: Crapcan
I was wondering where you had been
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (08-10-2021) |
08-10-2021, 02:25 PM | #130 |
Life has been crazy. My boss got fired for his grievances with me and life has been getting a lot better for me since his departure. Now that I'm not spending my days escaping via this forum, I'm just visiting much less still dedicated and excited! Just spending my time on the computer far more sparingly.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
08-10-2021, 02:29 PM | #131 |
Drives: Bone stock
From the dead.
Sent from my SM-G998U using Tapatalk |
The Following 2 Users Say Thank You to Joveen For This Useful Post: | BrahmaBull1990 (08-10-2021), DarkPira7e (08-10-2021) |
08-11-2021, 06:59 PM | #132 |
Also, VEMS started tearing into my old engine to see what happened. 4 broken rockers, and the crank nose sprocket is damaged, wtf. No idea how the crank sprocket got taken for a ride, but VEMS said the timing cover did not have OEM sealant, so someone had been in there before...
08-11-2021, 07:35 PM | #133 |
Drives: Crapcan
There was another thread where one had broken from them trying to start the car with a breaker bar still on the crank bolt. In your case, I would say something may have gotten between the chain and sprocket, possibly piece of rocker arm.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (08-11-2021) |
08-26-2021, 07:02 PM | #134 |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
Just read this whole thread. Can't wait to see what you put down. It's refreshing to see something different.
NARFALICIOUS
Noob Poster 1988 | 2016 |
The Following User Says Thank You to NARFALICIOUS For This Useful Post: | DarkPira7e (09-02-2021) |
09-02-2021, 07:26 AM | #135 |
Quick update-
Engine is in time, front cover and upper oil pan on. Worried about how hard the direct injectors went in, I'm hoping I didn't shred the seals. I left the injectors in the freezer, gave them each a small layer of dielectric grease, and they still pressed in pretty hard. They eventually slid in on their own, I'm certain there's nothing I could've done differently. If I have fueling issues, I'll know where to go first Waiting on the rubber washer gaskets for the lower oil pan, forgot to order them. Goal is to have the engine back in the car over the weekend, and then I can start adding all the goodies back to it. We'll see! On a side note, I had the opportunity to purchase my dream winter beater. Japanrot red E46 325xi. The guy knew me and let me take the car home to look over it. But, the floor had rusted out where the jack points go, and all 4 corners were trash. I shined up his headlights as a thank you for letting me take it home to check it out. So hard to bring it back, but I know better.
The Following User Says Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (09-02-2021) |
09-06-2021, 06:46 PM | #136 |
Labor day was not wasted! Getting close
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post: | Code Monkey (09-13-2021), Dzmitry (09-08-2021), MrSkubi (09-15-2021), NoHaveMSG (09-06-2021), Stonehorsw (09-07-2021) |
09-06-2021, 06:56 PM | #137 |
Drives: Crapcan
It’s beautiful
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (09-07-2021) |
09-07-2021, 07:41 AM | #138 |
I was on the fence about getting the red intake manifold for the bling, but I'm glad I stayed with the black one. Still missing a couple little things but it's there! It hasn't hit me yet that my car may actually run soon.
Bring on the oil leaks and poorly seated injectors, I'm ready to fight
09-13-2021, 01:59 PM | #139 |
Progress!!! Still waiting on things but it's in!
09-13-2021, 02:46 PM | #140 |
Drives: Bone stock
Man . Looks great buddy.
The Following User Says Thank You to Joveen For This Useful Post: | DarkPira7e (09-13-2021) |
Tags |
brz, frs, iag, jdl, turbo |
Similar Threads | ||||
Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 12-11-2023 05:59 PM |
Cxracing turbo problem | Kalebhall | Forced Induction | 10 | 11-16-2017 07:57 AM |
Tony's Budget Turbo Build | glorydays | Member's Car Journals | 22 | 01-25-2015 11:02 PM |
My boosted build...on a budget | PineappleFriedRice | Member's Car Journals | 95 | 08-17-2014 09:29 PM |
Aznsky's budget STX build | Aznsky | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 08:44 AM |
