01-21-2022, 03:51 PM | #29 |
FNG
Drives: 2013 Subaru BRZ
01-21-2022, 04:17 PM | #30 | |
Or to look at another example, the nb, nc, and nd miatas are all split on purpose so you aren’t allowed to do cross generation engine swaps. |
The Following User Says Thank You to strat61caster For This Useful Post: | RT-BRZ (01-21-2022) |
01-21-2022, 06:50 PM | #31 | |
Drives: LP DSP / CSP '13 BRZ
That is a factor of full prep (csp) vs limited prep (dsp) as update backdate is not allowed in Limited Prep. |
The Following 2 Users Say Thank You to Eric1855 For This Useful Post: | RT-BRZ (01-21-2022), strat61caster (01-21-2022) |
02-02-2022, 10:38 PM | #32 |
Drives: brz
The information in all the prior STX threads was great, and really helped a new guy figure it out, so here's my contribution.
This season will be my 3rd. Been slowly upgrading and growing with the car. 2019 BRZ Base - Tein Mono Racing coilovers, 10k/10k springs - Perrin 19 mm front sway bar set full stiff. - Stock rear bar - SPC rear arms with DIFtech bushings. I hate these. Squeaky and loud once i swapped the Difftech bushings in. The SPC LCAs should be grandfathered in. - 17x9 APEX ARC-8 +42 offset. Getting some minor rubbing on the front drivers side inner plastic liner. - 245/40/17 Falken 660s or RE71s New parts installed over the winter break are below. Looking forward to the extra power. I'm not sure how much of a difference it will make in times, but it sure feels a lot nicer driving around without the torque dip. - JDL 4-2-1 EL header - JDL OP and Quiet catted front pipe. - Stock catback. New local site has an 85 db limit. Stock catback doesnt sound half bad with the catless 421. - CSG Ecutek tune - STi motor mounts - Torque Solution Trans insert. I also plan to go from 3.5 to 4 camber in the front and try some A052s once the falkens wear out. Last edited by gordo52; 02-03-2022 at 12:10 AM. |
02-02-2022, 11:31 PM | #33 |
Real happy with whiteline rear lca, same as spc but with a poly bushing inboard, no noticeable nvh impacts vs what was there before.
Got em on tire rack, great shipping once they arrived stateside. |
The Following User Says Thank You to strat61caster For This Useful Post: | smg1138 (04-04-2022) |
02-03-2022, 09:03 AM | #34 |
Drives: 2016 Toyota 86
Why does everyone go for rear lower control arms instead of rear upper control arms?
I would think getting camber from pulling the top of the wheel inward rather than pushing the bottom of the wheel outward would be more ideal for suspension geometry and put less stress on the components. You would also get more similar fitment to the front where you are primarily getting camber from the top with camber plates. Mismatches in wheel fitment also seem to negatively effect the traction control systems in these cars. |
02-03-2022, 09:43 AM | #35 |
Drives: 2022 GR86
Upper and lower control arms are not separated as much as the full diameter of the tire. So pushing the bottom out, will bring in the top of the tire. Not as much as adjusting the upper control arm, but adjusting the lower, will bring in the top of the tire some.
02-03-2022, 10:33 AM | #36 |
Drives: 2016 Scion FRS
Recommended spark plugs for STX tuned cars?
02-03-2022, 10:46 AM | #37 |
Drives: 22 BRZ limited
The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | ka-t_240 (02-03-2022), strat61caster (02-03-2022) |
02-03-2022, 02:26 PM | #38 | |
Adjustable bushings in the upper arm should be legal though and cheaper then both, but more of a pain. This isn't a Miata so the rear suspension isn't designed to be adjusted up there. You're probably right in that it's *theoretically* better, but not enough to show up on course when missing an apex by a foot will add a tenth to your best time. Especially given that you're paying an extra $500, that's almost 2 yokes! Edit: +1 on stock plugs, high compression engine with weird Toyota direct injection system, not sure if the aftermarket is going to spec anything 'better', there are cheaper options but I don't think there's any gain there. |
02-03-2022, 10:18 PM | #39 | |
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
The Following User Says Thank You to Autoxer62 For This Useful Post: | Mike_ZN6 (02-03-2022) |
02-03-2022, 11:09 PM | #40 |
Drives: Miata
The Following 3 Users Say Thank You to racingfool For This Useful Post: |
02-03-2022, 11:55 PM | #41 |
That’s the strut section, for the rear of an 86 h.1 is the correct section:
On double/unequal arm (e.g., wishbone, multi-link) suspensions, only the upper arms OR lower arms may be modified or replaced, but not both. Non-integral longitudinal arms that primarily control fore/aft wheel movement (e.g., trailing arm(s) or link(s) of a multi- link suspension) may not be replaced, changed, or modified. That’s from ‘21 rule book, I’m hoping the updated wording goes into the ‘22. |
02-04-2022, 02:54 PM | #42 |
Yes, but the bushings are free as long as they aren't metal. The control arm remains stock.
Similar Threads | ||||
The 2022 Autocross Thread | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 11 | 02-26-2023 05:13 AM |
STX setup sharing thread (2021) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 366 | 12-07-2021 01:57 PM |
STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 01:40 PM |
STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 11:27 AM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
