01-31-2018, 07:10 PM | #141 | |
I Bought an automatic brz and wanted to explain why.
More importantly the MT is always attached to the drive wheels (assuming you have the clutch out) therefor you get engine braking which is extremely important for moving the weight between the front and rear wheels. When lifting on a traditional auto it disengages from the drive wheels so no weight will shift forward. You end up having to LFB to move any weight forward. Again, there is a lot more to an MT than shift time. |
01-31-2018, 07:27 PM | #142 | |
Drives: 2014 BRZ Limited
Personally, I've never driven a car with an automatic transmission where I didn't feel like the transmission was between me and the rest of the car. With a manual, I feel like I become part of the machine, like the machine is an extension of my body instead of a piece of dead machinery I'm operating. I don't think about shifting. It just happens, like walking.
I worked in television for ten years, and I felt the same way about my cameras. Most professional television cameras don't have auto-focus, but they do have auto-iris and auto-white balance. They also have rockers for the zoom, but most have a switch on the bottom to turn the servo off to be able to zoom manually. Most of the time I shot with everything turned off, because the camera felt more like an extension of my body that way. I was then able to (mentally) focus on what I was seeing through the viewfinder instead of being distracted by the machinery I was operating. There were some things the camera could do better than I could. The zoom servo, for example, was smoother than I could turn the ring with my own hand. But that just meant I knew when to flip the zoom over to the rockers and when to leave it on manual to snap zoom to the focal length I needed for static shots. Kind of like using cruise control when it makes sense and turning it off when it doesn't. Maybe some of you achieve that connected feeling with paddles, but I honestly don't see how. Quote:
Straw man. Nobody is saying that. |
01-31-2018, 07:36 PM | #143 |
Same car all other things being equal:
MT = Most fun driving ever AT = Sucks and boring no matter what You can deny people are saying that all you wish I see it as clear as day.
01-31-2018, 07:38 PM | #144 |
01-31-2018, 07:57 PM | #145 |
Drives: 2017 BRZ WR Blue
Regardless of what is mechanically superior or not, to me there is something missing from the driving experience when I'm not shifting. Ultimately that's why I prefer to drive stick, because it just feels right. Other people prioritize different things, but I will always have more fun driving MT than AT.
The Following 2 Users Say Thank You to HSUBLU For This Useful Post: | ermax (01-31-2018), extrashaky (01-31-2018) |
01-31-2018, 08:00 PM | #146 |
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (02-01-2018) |
01-31-2018, 08:08 PM | #147 | |
I can speak for myself that although the tranny isn’t all there is to a car it is a big enough part of it to totally ruin it for me. If I have an option I will pick the manual. If it isn’t an option I pick another car. The problem is the bench racers are killing it for the rest of us. |
The Following User Says Thank You to ermax For This Useful Post: | extrashaky (01-31-2018) |
01-31-2018, 09:04 PM | #148 | |
Road-hole
Drives: 2013 Whiteout FR-S
you're just a fucking troll...
There is no difference between the auto in our cars and the auto in high performance dual clutch transmissions in regards to your argument that MT are better in sports cars. Jaden |
01-31-2018, 09:07 PM | #149 | ||
01-31-2018, 09:35 PM | #150 | |
The Following User Says Thank You to funwheeldrive For This Useful Post: | weederr33 (02-01-2018) |
01-31-2018, 09:48 PM | #151 | |
Road-hole
LOL...
Is there a single type of auto tranny that is superior?? Sure.. A dual clutch or a clutched start sequential is the most superior trans type out there today. Are there auto's that are traditional style that are superior? For drag, absolutely. With modern paddle shift traditional AT trannies, there are literally no performance inferiorities except launching and 'fun'(which is subjective) when WHP is equal. Jaden |
01-31-2018, 10:25 PM | #152 | ||
Still confirmation bias. You're completely blind to the part of his post that doesn't fit with what you want to see. Too bad. |
01-31-2018, 10:32 PM | #153 |
When WHP is the same. Hahaha. In other words you need a more powerful engine to compensate for the inefficiency of the torque converter.
If the auto can do these things I would say it’s equal other than fun factor: Upshift within 250ms of command Downshift within 250ms of command Keep gear engaged when off throttle (engine brake) No additional power loss through tranny vs that of MT Rev match on downshift to prevent upset of balance mid turn Skip gears on downshift. (6th to 3rd for example) Same ratios and final drive I already know the 86 auto fails on a bunch of those points but not sure about a few things. Will it keep the gear engaged when off throttle or does it go neutral when lifting the way a traditional auto does. If your in 6th and triple tap down, will it go directly to 3rd or does it drop one gear at a time? How well does it rev match? For example from 2nd to 1st at 25mph, can it do that without a jolt? Looking on YouTube it looks like it up shifts after about 500ms and downshifts after about 750ms. 500ms is fine for an upshift. Timing on an upshift isn’t all that important anyways. 750ms before downshifting is a tad slow IMO. But not bad. It’s hard to judge how well it rev matches or if it engine brakes from watching YouTube videos. |
01-31-2018, 10:33 PM | #154 |
義理チョコ
I just watched this for the first time.
That's a 62 second quarter mile.
Tags |
automatic, why i bought |
Similar Threads | ||||
Can anyone explain this? | headlikeahole | Issues | Warranty | Recalls / TSB | 36 | 11-05-2016 02:40 PM |
Just Bought A 2016 WRX To Compliment My 2014 FRS. Just Wanted To Think Out loud. | steeloyangster | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 07-12-2015 11:44 PM |
new to OFT, can someone explain? | l0aded | Software Tuning | 7 | 03-22-2014 11:25 PM |
FI Guys: Were you more excited when you bought your car, or when you bought boost? | husker741 | Forced Induction | 28 | 02-25-2014 03:57 PM |
I'll try to explain | whaap | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 01-24-2014 09:35 AM |
