BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
12-01-2021, 07:03 AM | #15 |
Drives: 22 BRZ Limited
Some comparisons in this thread to the 1st gen trans, which I never owned, so I'm curious how this transmissions feels to other owners in absolute terms.
Overall I'm finding it very smooth, and I don't really get a lot of notchy-ness or resistance once it's warmed up. It actually seems to prefer being shifted fast - I can shift between upper gears as fast as I want and without being super thoughtful about it with zero complaining from the car. The one exception I have is going from 1st to 2nd... I can't for the life of me seem to hit that shift correctly most of the time without resulting in some level of lurch. Interestingly to me, this seems more exaggerated once the car is nice and warmed up. Is that pretty normal with these transmissions or am I the problem? I don't think I'm dumping the clutch too fast, letting the revs drop too much, etc... I can't seem to baby it enough to get it smooth. |
12-01-2021, 07:59 AM | #16 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
The Following User Says Thank You to Frost For This Useful Post: | timurrrr (12-01-2021) |
12-01-2021, 09:59 AM | #17 | |
Drives: 2023 BRZ
In my case, yes, the transmission was the problem.
Director of Rocky Mountain 86CUP
12-01-2021, 10:30 AM | #18 |
Totally - I'll upload one this weekend when I have a friend handy. It sounds like from your perspective, though, that this isn't kind of a known thing with the transmission which rules out a fast answer. Thanks! |
12-01-2021, 02:03 PM | #19 | |
But I do have tons of experience in slipping the clutch or lurching. In my old AP2 S2000, it had a clutch delay valve which forced me to slow down my shifts especially 1 -> 2. Once I got rid of it, it was gone. NOT saying the Gen2 twin has it but I've experienced things that make it difficult to do a quick shift from 1st to 2nd.
12-01-2021, 03:49 PM | #20 | |
I just got out over lunch and did a lot of experimentation... I think a couple of things are going on... I'm use to taller first gears and I think I'm just winding it out too much for how unaggressively I'm driving it most times. I'm also trying to protect the clutch too much, and need to let it slip a little more as it syncs up to 2nd. I'll keep playing with it... it does seem a bit touchy to me but I think I can compensate for that with how I manage my shifts. Thanks for the offer to review and give feedback! |
12-02-2021, 05:30 PM | #21 |
Drives: ‘22 BRZ
Quick question, has anyone noticed a thunk going into 1st from neutral? Sometimes in other gears as well. Feels like the synchros maybe. Nothing crazy just enough to notice it.
12-02-2021, 05:48 PM | #22 |
Drives: 2022 GR86
12-02-2021, 05:54 PM | #23 |
Drives: ‘22 BRZ
Yep, at standstill and sometimes while rolling. None of my other manual cars did that. This is my 4th.
12-02-2021, 05:57 PM | #24 |
TRACKBREAD
It’s because the gears in the transmission are still spinning after you push the clutch in, and putting it in gear forces them to stop. If you wait a second after clutching in they will spin down naturally and it won’t clunk.
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | slimfit (12-02-2021) |
12-02-2021, 06:04 PM | #25 |
Drives: 2022 GR86
The Following User Says Thank You to timurrrr For This Useful Post: | slimfit (12-02-2021) |
12-02-2021, 06:20 PM | #26 |
Drives: ‘22 BRZ
I’ll chalk it up to normal. Thanks guys!
12-02-2021, 06:21 PM | #27 |
Drives: 2022 BRZ, 1999 "touge-spec" Miata
The Following User Says Thank You to Interceptor777 For This Useful Post: | slimfit (12-02-2021) |
12-02-2021, 07:51 PM | #28 |
Drives: ‘22 BRZ
Hmmm, I should mention this is my first manual RWD car. Maybe it’s a trait of that?
Similar Threads | ||||
BRZ/FRS AZ6 Manual Trans Upgraded Gearset | RockySDS | Engine, Exhaust, Transmission | 169 | 09-15-2022 08:55 PM |
What Manual Trans Fluid Do You Use? | McG86 | CANADA | 50 | 03-22-2020 08:19 PM |
FRS/BRZ Manual Trans Fluid | shellslinger | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 131 | 11-02-2017 10:44 AM |
Manual Trans 12k miles $750 OBO | Amir Ghadiri | Transmission and Driveline | 4 | 05-23-2015 02:35 PM |
Bump start in a manual trans? | bayank | BRZ First-Gen (2012+) -- General Topics | 11 | 02-16-2014 06:47 PM |
