Old 01-16-2021, 09:28 AM   #1527
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Hi
I'll do my best to answer your questions, answers directly below in italics
Originally Posted by Koba View Post
Hello all,
Read most of this thread and just want to clarify some things prior to SC install:
I should mention that this will be a track only car, I instruct for a number of clubs in my area, so there will be a lot of track time, and once the car is sorted, a cage will go in for W2W. My previous race car was an E30.
1. Since I have a 2020 MY, it seems that all I need is a longer sleeve to connect to the air box and possibly a new filter (Blitz seems to be the recommended brand)... can I stick with stock or is there just too much restriction?
Is there anything else that is required for 2017+?
No that should be it
2. I am leaning towards Jackson dual rad/oil cooler, some people in this thread mentioned that they are using it, just wondering if anyone with a SC is tracking with this set-up, and if there are any cons?... I will be venting the hood too, mostly for aero, but should help with keeping the temps down.
oil cooler with a thermostat is a good idea and the beatrush undertray also helps keeps temps down
3. I should have more than enough power for the class I am aiming for with this SC, all I care about is reliability, so with that in mind:
a) Can I keep the stock exhaust (don't care about sound)? - [I]yes you can[/I]
b) Not because of power, but just to avoid any knocking issues, which octane?
I have easy access to:
91 no ethanol,
93 and 94 with about 10% ethanol,
and almost any octane non-ethanol race fuel - 94, 98 and 100... it's just bloody $$$[I]
94 octane with 10% ethanol will work well - the tune comes with 91 and 93 octane maps as standard[/I]
4. Please see attached picture - is this normal or just loose? Couldn't really check it at the time, and now the box is buried behind a bunch of crap (just a little paranoid).
why do you think that end cap is loose? the cap may not be 100% lined up but if the button head screws are tight it'll be fine, the cores are sealed in with silastic too and you almost don't need the screws
5. Engine oil - leaning towards 5w30 to start, will monitor temps and pressure. - [I]definitely, the stock 0W20 is too thin, also if your tyres are better than stock I'd strongly recommend a sump baffle as the pickup gets uncovered in long corners[/I]
6. Got a catch can, just because it makes me feel better. if you like but I'v e not found any need for one
I am sure that I will have more questions, but that is it for now. Thank you all!
Matt@Cosworth is offline   Reply With Quote
Old 01-18-2021, 02:50 PM   #1528
Koba
Drives: 2020 BRZ
Thank you, Matt!
Just wanted to confirm on the above points.
Loose was a wrong choice of words, it just threw me off a bit, but thank you for putting my mind at ease.
Koba is offline   Reply With Quote
Old 02-08-2021, 02:32 PM   #1529
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Two questions for you guys:
1) Anyone installed an intake snorkel to lower IAT or just keeping it stock?
2) My car is currently tuned for the SC with a Cat-back exhaust. Is it "safe" to drive without a tune if I install a catless header with a high flow cat?
Thanks !
botbs is offline   Reply With Quote
Old 03-28-2021, 11:46 PM   #1530
botbs
botbs's Avatar
I finally installed the Marsh Composites carbon hood. It is a lot lighter than stock hood (a bit of surprise there).
For those of you who has a Cosworth Supercharger, the passenger side does not clear the Cosworth Supercharger intake duct & Coolant Pump and a bit of cutting is required. After trimming the NACA duct that the hose will not be able to fit perfectly but can be installed.
Other than that the hood is very well built. Having said that the packaging is super awesome too! Definitely recommend to anyone who wants a nice hood!
The hood is a lot nicer in person than on photo IMO. I was not convinced when I saw it on the picture but I love the hood in person.
The Following User Says Thank You to botbs For This Useful Post:
weederr33 (05-14-2021)
Old 03-29-2021, 01:11 AM   #1531
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Thanks !
Nice hood and good choice given that these cars are a bit front heavy.
About your other questions, I wouldn't change anything since this might lead to ECU tweaking again.
The Following User Says Thank You to nikitopo For This Useful Post:
botbs (03-29-2021)
Old 03-29-2021, 01:43 AM   #1532
botbs
botbs's Avatar
Thanks! I got this vented hood just hope to minimize the knock and IAT if possible.
Matt sent me an update on the tune =)
Thanks all for your help!
nikitopo (03-29-2021)
Old 05-14-2021, 01:24 PM   #1533
botbs
botbs's Avatar
HKS catted header arrived finally, this is my last bet on addressing knock issue.
Old 05-14-2021, 02:55 PM   #1534
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Heyyyy I had that same kit! It makes for a very good sounding system when paired with the Legamax Sport or the TRD axelback.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
botbs (05-14-2021)
Old 05-15-2021, 04:16 PM   #1535
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
God I love these wheels! car is looking great. Ok back on topic sorry!
Elliotw is offline   Reply With Quote
Old 05-15-2021, 05:52 PM   #1536
botbs
botbs's Avatar
Thanks! Those TWS wheels are super light and I love it too. Wrapped the hood and now looks like this.
The Following 4 Users Say Thank You to botbs For This Useful Post:
Elliotw (05-15-2021), nikitopo (05-21-2021), Stonehorsw (05-28-2021), tomm.brz (05-16-2021)
Old 05-19-2021, 02:01 PM   #1537
weepel
Dr. Fünke, Analrapist
weepel's Avatar
Drives: 2013 BRZ Limited, 2004 WRX STI
I've joined the team
Got my (used) kit installed the other week!
2013 Subaru BRZ Limited
2004 Subaru WRX STI
My Garage, past and present
weepel is offline   Reply With Quote
The Following 3 Users Say Thank You to weepel For This Useful Post:
botbs (05-20-2021), dpfarr (09-11-2021), Stonehorsw (05-28-2021)
Old 05-26-2021, 08:25 PM   #1538
botbs
botbs's Avatar
Got my catless header with HFC installed, night and day difference.
I should have gone for this route instead of cat-back only.
nikitopo (05-27-2021)
Old 09-10-2021, 09:30 PM   #1539
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
70,000 miles and running perfectly. Anyone know where to find another Cosworth Aluminum badge? The one the front of my car has faded.
https://www.rallysportdirect.com/par...aluminum-badge
Also, at what point should I consider changing the Supercharger oil? Anyone have the viscosity and capacity?
sly is offline   Reply With Quote
The Following User Says Thank You to sly For This Useful Post:
weederr33 (09-10-2021)
Old 09-10-2021, 09:58 PM   #1540
weederr33
weederr33's Avatar
I think at this point, ebay would be the only option.
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4306 04-18-2024 06:23 PM
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6004 03-19-2024 02:16 PM
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
