02-11-2021, 08:29 PM | #1303 |
That Guy
Drives: 2013 asphalt FRS MT
02-12-2021, 04:41 PM | #1304 |
Drives: Crystal White BRZ
Talked with Jesse @ JDL & their fixing the manifold to fit
03-03-2021, 03:55 PM | #1305 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Another JDL turbo owners having replace the air filter and the end of turbo inlet over and over again?
Instagram: 86_Maul |
03-04-2021, 10:08 PM | #1306 |
Well, i am happy with my kit. Everything running smoothly after my accident of not clamping a coolant line and spraying it all over my engine/hood. Its back on the road, dual catch can from radium. Thinking eventually built motor/bigger turbo etc
Follow on IG-- Limitless_brz |
The Following User Says Thank You to Limitless_BRZ For This Useful Post: | FRS_FIEND (03-08-2021) |
03-08-2021, 04:04 AM | #1307 | |
Whats next?
Drives: '13 Asphalt FRS MT
Life is too short to drive a boring car...
Instagram: @angelb_af |
03-08-2021, 04:15 AM | #1308 |
Whats next?
Finally got my car tuned last week! 396hp on e85 (e70) and 314hp on 91 10psi its a different car. I will only be using e85, no more 91 for me. I need to figure out on how to loosen my wastegate spring. My tuner was telling me that it was too tight, it is the 7psi spring and I am using a 3 port boost solenoid. any takers on what the tuner means by loosening the wastegate spring? I tried googling and yt and just cant find anything.
03-08-2021, 07:49 AM | #1309 | |
Rust bucket enthusiast
Congratulations on getting your car all set and running, take care of it!
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
03-08-2021, 06:10 PM | #1310 | |
i did give up for 3 days while waiting for new hoses, reducers and clamps from summit racing lol But i haven't got it dyno'd yet.. noticed today with the ECU phone app while driving hit 241 lb torque on a 3rd gear pull. not bad, but i noticed while doing that that i had a boost creep to 9lbs ! |
The Following User Says Thank You to Limitless_BRZ For This Useful Post: | FRS_FIEND (03-23-2021) |
03-23-2021, 01:31 AM | #1311 | |
Whats next?
thanks for the jogging my memory and advice bro. trust me I do take care of it. I've had it since 2013 and its been garaged all its life, its my baby. just replaced my old coilovers with some HKS Hypermax ones (6k,4k), tuner said previous supsension was too stiff (8k,8k) making the tires break loose on the dyno. My pilot super sports were sitting for a long time because of a deployment and they were old. Replaced my coilovers anyway because I've had them since mid 2014 and got new Falken fk510s. I will be upgrading to Toyo r888s once I find wheels that can replace my Advans, which is hard af lol Anyway long story short I have a lot of money into my car and I never stop buying new car parts for it and keep most of my old parts lol.
The Following User Says Thank You to FRS_FIEND For This Useful Post: | CSG Mike (04-01-2021) |
06-12-2021, 04:13 PM | #1312 |
Drives: Toyota GT 86
Why the cold air intake is no longer available? I desperately need one!
07-23-2021, 10:10 AM | #1313 |
Drives: '16 FRS-MT Ablaze Red
I ordered a JDL kit with 2860rs turbo. My goals are 300whp using 93 now and then 300whp with e85 in the future. I'm looking at the southbend stage 2 daily (rated for ~315 tq) and southbend stage 3 daily(rated for ~400tq). Should I go stage 2 or stage 3? Anyone have issues slipping on stage 2?
Thanks |
07-23-2021, 10:49 AM | #1314 |
I would just get the stage 3. Remember these are rated at the crank or in the case flywheel and not whp and wtq
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | trinidadj (07-23-2021) |
07-23-2021, 02:21 PM | #1315 |
09-14-2021, 10:52 PM | #1316 |
What are people doing for a filter on a 4" inlet? I bought an AGP filter but it's too long. I'm going to run a turbo screen for the time being, but I'm curious what others have done. A filter straight off the inlet puts me straight into the front support framework
I'll likely end up putting an ugly looking pipe + filter into the pocket where the windshield washer reservoir lived.
Similar Threads | ||||
HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 08:03 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
