07-26-2024, 01:15 PM | #15 |
First 86 Driver Baby!
Drives: FR-S, Flex
The Following User Says Thank You to kmbkk For This Useful Post: | autoracer86 (07-26-2024) |
07-27-2024, 10:32 AM | #16 |
Drives: 2013 frs base
07-27-2024, 02:15 PM | #17 |
The loose belt was caused by using my 2013 belt. The water pump pulley on the 2022 is smaller than the 2013. Just my luck, none of the local part stores stock the 2022 belt nor the 2013 intake cam position sensor. I ordered both items from RockAuto and will get them next week.
Offset and center hole size on the pulleys are different so the 2013 pulley won't work on the 22 engine. |
The Following 4 Users Say Thank You to blsfrs For This Useful Post: |
07-27-2024, 08:29 PM | #18 |
Drives: Toyota 86
Are other pulleys same?
I'd like to reuse my electric water pump on FA24 so the water pump pulley might not be an issue. My 2013 engine was blown and stock FA24 was sourced. I wonder how RS Motors kit solved the CPS target wheel interference.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ Last edited by makinen; 07-28-2024 at 03:19 AM. |
07-27-2024, 09:17 PM | #19 | |
07-28-2024, 03:18 AM | #20 | |
Drives: Toyota 86
I already have two sets of stock cam gears. No more cam plates, please.
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
07-28-2024, 11:57 AM | #21 | |
Other posters have speculated that RSM puts the crank trigger plate in a press and flattens it out. Maybe he takes it out to his parking lot and runs over it a couple of times. |
The Following User Says Thank You to blsfrs For This Useful Post: | makinen (07-28-2024) |
07-28-2024, 06:46 PM | #22 |
Swapped intake cam position sensors Pass to driver's. My P0341A did not change. Now, I've got to dig a little deeper. RSM is available to help but from afar. I found a diagnostic procedure for a 2013 Outback. I'll try to replicate it with mine.
I was working on hooking up a new oil cooler. I thought I would reuse my lines but I kept getting shiny bits when I flushed oil through one of them. Ordered some new AN10. |
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (07-29-2024) |
07-28-2024, 07:10 PM | #23 | |
Drives: Toyota 86
It should be the easiest way to bent the target wheel and make a sensor adapter for that.
The Following User Says Thank You to makinen For This Useful Post: | blsfrs (07-29-2024) |
07-28-2024, 07:37 PM | #24 | |
Drives: Toyota 86
Possibly caused by the gap between the sensor and the cam trigger plate? BRZ TSB 11-130-13 CAM POSITION SENSOR.pdf
07-29-2024, 09:00 AM | #25 | |
08-03-2024, 07:12 PM | #26 |
Got my new belt. Fits like it was made for the car...Oh yea, it was. Lesson: you can't use the 2013-2016 belt on the FA24's
I tracked down the P0341 code to a loose wire in the plug to the sensor. RSM is sending me a new pigtail. None of the local part store had the right one. |
The Following 9 Users Say Thank You to blsfrs For This Useful Post: | brandonblt2 (09-17-2024), CkOne (08-08-2024), NoHaveMSG (08-04-2024), Spankopotomous (08-16-2024), T-Steve (08-03-2024), Tatsu333 (08-09-2024), Ultramaroon (08-05-2024) |
08-12-2024, 12:52 PM | #27 |
Still getting P0341. RSM sent a replacement plug. I installed it and continuity was good on all 3 wires. Cleared codes but CEL came on when I started the engine. My Actron code reader shows 2 P0341's. One is listed as "pending".
I drove the car around. Got it up the 200* oil temp. Cleared the codes and my CEL was off when I refired the engine but it came back on when I blipped the throttle. Same 2 P0341's. I saw a clip of a guy on Youtube who said it may take several drive cycles for some cars to clear a code once the problem is solved. I'll drive it around this week and see what happens. If it doesn't clear, I'll do some datalogging. |
The Following User Says Thank You to blsfrs For This Useful Post: | Teseo (08-12-2024) |
08-12-2024, 12:52 PM | #28 |
The Following 5 Users Say Thank You to blsfrs For This Useful Post: |
Similar Threads | ||||
FA24 swap to a GT86 ? Anything I need be aware of? | twasd | Engine Swaps | 23 | 01-09-2024 10:28 PM |
Viability of complete FA24 swap (motor and ECU)? | Tatsu333 | Engine Swaps | 43 | 02-18-2023 06:18 PM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
