Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-20-2012, 04:09 PM | #1 |
Re-member
Drives: Toyota camry
Where does all the rear weight come from?
This car has a pretty good weight distribution, as we all know. But when I picture things in my head I see an engine and a transmission with their weight almost completely supported by the front suspension. In the back is the diff and fuel tank (not so heavy). How does this car achieve a near 50 50 weight distribution with almost all of the heavy stuff at or in front of the front wheels? Where does the weight supported by the rear suspension come from?
Nothing decays like progress, and nothing preserves like neglect.
09-20-2012, 04:52 PM | #2 |
Grease Monkey
Drives: Whiteout FR-S
well, first of all, the engine and tranny sit VERY low and VERY far back. Then u have the big driveshaft coming from the tranny to ur LSD diff, rear axles, then finally gas tank, spare tire (and tools), rear seats, muffler, etc.
The center of gravity on this car is a few inches behind the shift knob.
R.I.P. '92 Honda Prelude you will be missed
09-20-2012, 04:57 PM | #3 | |
When In Doubt...
Drives: Slowww
I guess this could be calculated pretty easily but do you have a source for this? Not doubting it, just curious. Also, the fuel tank might not be that heavy but I believe the weight distribution is listed as being a wet weight (with fluids). 13 gallons of gas at 6 pounds/gallon = 88 pounds or about 7% of the rear weight.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
09-20-2012, 05:06 PM | #4 |
Ridge Racerrrrrrrrr
There is a lot more "body" and "structure" to the rear I would argue. cabin, trunk, crash protection for the passengers, etc
09-20-2012, 05:13 PM | #5 |
Grease Monkey
@Laika, saw a diagram on some website. been searching for it but cant find it anywhere. it was legit. ill keep searching for it and post up when i find
09-20-2012, 05:16 PM | #6 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Its not nowhere near 50/50. It is 55/45 with nobody in the car.
09-20-2012, 05:21 PM | #7 |
Drives: 13 White MT FR-S
I heard from multiple sources that it was 53/47
The Following User Says Thank You to ML For This Useful Post: | 20valvewynn83 (09-20-2012) |
09-20-2012, 06:17 PM | #8 |
Drives: Firestorm FR-S (MT)
The Following 2 Users Say Thank You to Shagaliscious For This Useful Post: | 20valvewynn83 (09-20-2012), Chad (09-23-2012) |
09-20-2012, 06:34 PM | #9 |
Re-member
It just seems that the motor and tranny are the vast majority of the weight. From a mass perspective there just seems to be a lot less stuff in the rear. How much does a drive shaft and diff weigh compared to an engine block and tranny? The weight distribution is just hard for me to visualize.
09-20-2012, 06:56 PM | #10 |
First 86
Drives: Scion FRS Argento Automatic
Why the difference between the 2 cars?
Life is short...NO BORING CARS |
09-20-2012, 07:15 PM | #11 |
that strikes me as odd since the brz should have more amenities in the cabin. ive heard that the cars were 53/47 with people in the car and 55/45 without. was that what you were thinking of? otherwise, youre talking about a 50 lb shift in nearly identical cars
09-20-2012, 07:37 PM | #12 |
Drives: Raven Black
50L of fuel is in the back too. That's over 100 pounds.
09-20-2012, 07:49 PM | #13 |
Re-member
Thats BS, few will have people in the back, a spare tire, and a full tank of fuel when things get twisty. Ill bet these cars are more like 60/40 real world.
09-20-2012, 07:56 PM | #14 |
Drives: '13 Ultramarine
The Following 3 Users Say Thank You to roddy For This Useful Post: |
Similar Threads | ||||
Help Removing Rear Seats and Rear Part of Center Console | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-27-2012 03:11 PM |
curb weight | 7thgear | BRZ First-Gen (2012+) -- General Topics | 8 | 07-17-2012 04:05 PM |
Weight..... | icemang17 | Tracking / Autocross / HPDE / Drifting | 2 | 07-02-2012 06:24 PM |
Non USDM BRZ oil weight | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-21-2012 02:55 PM |
Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 10:43 PM |
