go_a_way1
Old 10-01-2020, 10:49 AM   #4313
rannyBg
Drives: 20' GT TRD
16 inch winters for 2020 86GT TRD package
Hi folks - super new here - tried to poke around but can not find answer..
Is there a 16inch setup for TRD package 86? Or if not - what is the skinniest rim in 17" I can fit?
thanks a bunch!
rannyBg is offline   Reply With Quote
Old 10-01-2020, 11:19 AM   #4314
Vital
Drives: 2015 BRZ
thanks a bunch!
As far as i know these cars do not come with 16" wheel an tire packages in the US. Heres a couple threads to help you. If the TRD 86 packages comes with Brembo's then disregard these links as fitment will be different...
https://www.ft86club.com/forums/showthread.php?t=113691
https://www.ft86club.com/forums/showthread.php?t=62320
Old 10-05-2020, 12:04 AM   #4315
wil5bart
Drives: '16 BRZ
I'm planning to get 18x8 american racing rims particularly the Torq Thrust. It has +41 offset. Will they sit flush on my '16 BRZ? Also, what's the max tire size?
wil5bart is offline   Reply With Quote
Old 10-05-2020, 10:30 AM   #4316
Vital
Drives: 2015 BRZ
No, they will not be flush you need at least +35 offset. The max tire size you can use with that wheel is a 245/35/18.
The Following User Says Thank You to Vital For This Useful Post:
wil5bart (10-12-2020)
Old 10-12-2020, 09:01 PM   #4317
wil5bart
Drives: '16 BRZ
Thanks. I found a set of used XXR 527 so I might go with that route.
The Following User Says Thank You to wil5bart For This Useful Post:
Vital (10-14-2020)
Old 11-07-2020, 08:59 AM   #4318
ClevelandFRS
ClevelandFRS's Avatar
Drives: Scion FRS 2013
I'm sitting here right now in a car shop that has accidentally broken something small on my car dash during a detail. They offered me a 50% off discount on Blizzak tires, I can order whatever model I want if they don't have it in stock.
But, they do have it 4 WS80 215/55R17 tires here they can install now. Will these actually fit? I'm trying to get a confirming second opinion before I order anything.
ClevelandFRS is offline   Reply With Quote
Old 11-08-2020, 01:59 PM   #4319
Vital
Drives: 2015 BRZ
Yes they will fit, as long as you have OEM wheels or any 17" wheel that is 17x7 17x7.5 & 17x8. Those tires will just be taller than OEM tires but it will fit fine.
Old 11-08-2020, 03:55 PM   #4320
anticubus
Drives: 2017 Toyota 86
That's a good deal, but I'd push for a set of WS90s. WS80s are guaranteed to be at least two years old now, and winter tire rubber has a limited lifespan.
I'll also say the WS series isn't actually my top pick for Cleveland anymore. I run a set on the Matrix (So ~100WHP on a really good day.) and the spring temperature flips really eat up the rubber when it gets warm for a few days then dumps back to 30f for a week. Two years in and one pair is almost through the upper 50% of tread with the really soft rubber, and the other pair will probably be gone by the end of the winter.
If you haven't jumped see if you can get some WS90s or the newer X-Ice Snows. I have some X-Ice 3s for the 86 and they're doing great after 3 seasons. They're great through the snow storms and don't get eaten up as much on dry pavement.
anticubus is offline   Reply With Quote
Old 11-08-2020, 04:32 PM   #4321
churchx
churchx's Avatar
Drives: 2014 GT86
anticubus: properly stored tire degrades little. I'd expect not more then eg. 10%/3-5 years, worsening for modern tire in storage warehause. It's when it in actual use, "clock really ticking for it", as rubber wears down, goes through heat cycles, some possible additives dissipate, roadsalt and other road chemistry and so on .. and if for some tires last even past 3 years of real use ..
So imho it's safe enough to get upto 3 years old tires, especially if they come with some good deal that more then offsets slight potential degradation.
Old 11-14-2020, 05:31 AM   #4322
Madara808
Drives: PP WRB BRZ
Will TE37SL 17x9.5+45 wrapped in 255/40 RE71Rs fit without rubbing? I’m currently lowered about 1” on Ohlins with SPL RLCAs.
Madara808 is offline   Reply With Quote
Old 11-14-2020, 02:25 PM   #4323
Vital
Drives: 2015 BRZ
Yes with coilovers you should be fine. Keep in mind that every tire manufacturer have different tolerances so even if they are the same size tires some may be wider or narrower compared to a different manufacturer.
Old 11-23-2020, 11:05 AM   #4324
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
My prediction is a tiny bit of rub at full deflection in the front
AKITA is offline   Reply With Quote
Old 11-24-2020, 01:40 AM   #4325
Madara808
Drives: PP WRB BRZ
Ah might have to buy rack limiters or something then. We’ll see
Old 11-24-2020, 05:14 PM   #4326
Vital
Drives: 2015 BRZ
Or you could just get 3-5mm spacers. I wouldnt run any larger than that on stock length studs. Or just buy proper size wheels...
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
