Member's Car Journals Car journals by our members. |
06-06-2014, 08:33 PM | #15 |
In. This is going to expensive
06-06-2014, 09:16 PM | #16 |
Car N00b
Drives: 97 Miata
Woah.
Incredibly brave to do something like this. Can't wait to see what happens. |
06-06-2014, 09:34 PM | #17 | |
Drives: 2013 Subaru BRZ
Basically it totally depends on how hot the fire got (which there's an upper limit on, E85 flame only gets so hot), how long it stayed there, how fast the fire was quenched, the composition of the steel, etc. Mild steel that car frames are made out of doesn't really harden as much as a higher alloy steel would have. Also, if I stitch weld the front end, it should relieve most of the internal stresses that the fire may or may not have induced. edit: I have no idea what this diagram means. Last edited by SomeoneWhoIsntMe; 06-06-2014 at 09:57 PM. |
06-06-2014, 09:52 PM | #18 |
Drives: 86
Holy reverse necroviscontuning!
The Following User Says Thank You to juliog For This Useful Post: | DAEMANO (06-07-2014) |
06-06-2014, 10:25 PM | #19 |
The Answer
Drives: Mazda 2
You got the thread title right.
Serious question, what is your estimate to bring her up to standard again? I can only imagine the time spent on each and every single component that is damaged in the bay (there is virtually NOTHING good on the front half of the car), ugh.. good luck.
06-06-2014, 10:29 PM | #20 |
Dismember
Drives: FR-S & JSW
I showed this to my local metallurgist who specializes in steel heat treat. She says its probably almost good as new, just bend/weld it back into shape and you'll be fine.
The fault lies not in our cars, dear Brutus, but in ourselves.
The Following 2 Users Say Thank You to Shim For This Useful Post: | DAEMANO (06-07-2014), Jive Turkey (01-07-2015) |
06-06-2014, 10:42 PM | #21 |
Drives: 86
, good luck buddy
06-06-2014, 11:01 PM | #22 |
Drives: 13 GTI
Saw this on copart. Glad to see something awesome is going to happen with it.
06-07-2014, 04:24 AM | #23 |
Drives: 2014 Subaru BRZ (Limited)
sub'd for updates! good luck good sir
The Following User Says Thank You to jbsali For This Useful Post: | SomeoneWhoIsntMe (06-07-2014) |
06-07-2014, 05:07 AM | #24 |
Drives: 2014 Pearl BRZ Limited
Sht just got real..
The Following User Says Thank You to edeekeos For This Useful Post: | SomeoneWhoIsntMe (06-07-2014) |
06-07-2014, 06:24 AM | #25 | |
Fortunately, I'm not looking to bring it up to standard. If Scion would have sold me a bare shell I would have gone with that, but they won't so this is the next best thing. |
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post: | Lonewolf (06-07-2014) |
06-07-2014, 06:28 AM | #26 |
Drives: 2013 FR-S, 2008 Fit
Wow, this is awesome!
I'm super excited to see a project like this done with a twin... especially THAT twin in particular! It would be cool if you got a custom plate that said "phoenix" or something like that, lol. My brother-in-law is super jealous of my FR-S and there's no way he could afford one anytime soon, so I've fantasized about getting my hands on a wrecked twin for cheap that we could patch up in some sketchy less-than-safe manner so we can rally it until the wheels fall off or something. Thanks for taking on such a project and sharing it with us, I hope it all goes good. |
The Following User Says Thank You to mitosis For This Useful Post: | DAEMANO (06-07-2014) |
06-07-2014, 06:44 AM | #27 |
/dev/null
Drives: Uphill
What's that engine you're planning to put in?
Good luck with the project! |
The Following User Says Thank You to Sarlacc For This Useful Post: | SomeoneWhoIsntMe (06-07-2014) |
06-07-2014, 07:07 AM | #28 |
Engine is a 1JZ-GTE VVTi out of a JZX100 chaser/markii/cresta. I'm going to use a pontiac solstice 5-speed with it because it's an aisin trans similar to the one that's supposed to go on 1jz's only cheaper and newer. I have an ace-up motorsports downpipe, that's probably going to be the only power mod along with deleting the stock bov and replacing it with an aftermarket one and adding a boost controller. Not sure what I'm going to do about EMS yet, I'd like to go AEM or megasquirt down the road, but the stock ECU is also perfectly capable of running the engine for now.
Once I go with standalone EMS or a decent piggyback, I'd like to get cams and a bigger stock location turbo. Unless I know for sure that won't satisfy me by then, I've got a 2jz-ge block I can rebuild to go 1.5jz. Last edited by SomeoneWhoIsntMe; 06-07-2014 at 07:23 AM. |
Similar Threads | ||||
Dreams | Priapus | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 08-04-2014 11:57 PM |
Front pipe choices, resonated vs straight pipe | jflogerzi | Engine, Exhaust, Transmission | 4 | 12-29-2013 10:14 PM |
Garage Life: We bring your dreams to life! | Garage Life | Southern California | 0 | 08-17-2012 07:33 PM |
BRZ/FR-S Dreams? | MrBRZ | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 03-22-2012 08:55 AM |
Dreams about the BRZ | 86'd | BRZ First-Gen (2012+) -- General Topics | 20 | 02-25-2012 10:58 PM |
