Xero Limit
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 05-19-2020, 04:15 PM   #1
Jwheelz
Drives: 2013 Scion FRS
Post Oxygen Sensors
Hello, first post. I have a 2013 Scion FRS and I recently had a motor swap. The engine has been running really rough and is currently running rich with a bunch of smoke burning out the exhaust. I suspect the problem is coming from the Oxygen sensors, but I need to know what the proper voltage specifications are for the Oxygen sensors? Does anyone know this info? Thanks.
Jwheelz is offline   Reply With Quote
Old 05-19-2020, 05:57 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The O2 and MAF operate in a voltage range. The only way to really test them is resistance across the pins at a specific temperature.
https://demos.starbase7.net/t3Portal..._rm_index.html
Look under Engine/Hybrid System -> FA20 Engine Control and the inspection procedure for the Air fuel ratio sensor and the heated oxygen sensor.
I doubt this is your issue though.
"One of the great challenges in life is: knowing enough to think you're right, but not enough to know you're wrong."
- Neil deGrasse Tyson
NoHaveMSG is online now   Reply With Quote
Old 05-19-2020, 07:54 PM   #3
Jwheelz
Thank you NoHaveMSG! I found what I needed under air-fuel ratio sensor inspection.
engine, exhaust, frs, rough idle, sensors
Oxygen sensor cross threaded. Zaneman Issues | Warranty | Recalls / TSB 13 07-05-2017 12:14 PM
DIY: Oxygen sensor spacer Hardrock4445 DIY (Do-It-Yourself) Guides 13 07-11-2015 11:43 AM
WTB: Stock oxygen sensor Njjawn NY / NJ / CT / PA 5 01-17-2015 03:53 PM
WTB: OEM Rear Oxygen (o2) Sensor xjohnx Want-To-Buy Requests 5 04-07-2014 10:32 PM
fluid dynamics, venturi effect, and oxygen sensors. EZWood Engine, Exhaust, Transmission 8 10-25-2012 06:21 AM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
