Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-11-2019, 03:56 PM | #57 | |
I wouldn't do that, I'd look for a set that increase the front and rear roll stiffness by the same amount. 1mm more on an 18mm bar is going to be different than 1mm more on 14mm bar.
The Following 2 Users Say Thank You to wparsons For This Useful Post: | Spuds (06-13-2019), Ultramaroon (06-11-2019) |
06-11-2019, 03:59 PM | #58 | |
I don't think he got that at all, and that's what I was pointing out. End links or attached directly to the strut, the only independent movement is through the sway bar twisting. We definitely agree on that, I was clarifying for the other guy.
06-11-2019, 04:08 PM | #59 | |
義理チョコ
Of course, for most of us, myself included, ballpark is all that matters.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Spuds (06-13-2019), strat61caster (06-11-2019) |
06-11-2019, 05:46 PM | #60 |
Drives: '15 BRZ RA
I wouldn't remove the swaybars from a suspension that was designed to work with them. The only application I can think of it would be off-roading usage, but this is not very relevant to our platform.
The Following User Says Thank You to nikitopo For This Useful Post: | norcalpb (06-11-2019) |
06-12-2019, 08:22 AM | #61 |
Anti stance.
A lot of fast FWD racers remove the rear sway, setup an extremely stiff front bar, and just drag a limp ass around.
06-12-2019, 09:59 AM | #62 | |
Only users lose drugs.
Drives: All the time
Also keep in mind that even though the rate rises exponentially, it's still a relatively small fraction of the total roll resistance at that wheel. As mentioned before, it's generally a tuning device if your existing setup is close to what you like.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
06-12-2019, 10:06 AM | #63 | |
Again, platform dependent. There was a popular suspension outfit at one point who had a very fast kit for A1 chassis VWs which did away with the front swaybar completely, and used a gigantic Carrera bar in the rear... The cars were undeniably quick, so the setup worked; it was just quite unconventional compared to the majority of other kits at the time.
The Following User Says Thank You to venturaII For This Useful Post: | Tokay444 (06-12-2019) |
06-12-2019, 10:13 AM | #64 |
The difference in effective wheel rate you get from going 1 mm stiffer in front vs 1 mm in the rear is a good point many often miss.
But what I think @Ultramaroon was getting at was...even if you increase front and rear wheel rates by exactly the same 10%, you could still be changing the handling balance of the car. - Andrew |
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
06-12-2019, 10:50 AM | #66 |
Anti stance.
06-12-2019, 11:10 AM | #67 |
Drives: Crapcan
That is the opposite of what I have heard on FWD. They are trying to eliminate push so you have to take grip from the rear to get the car to pivot. If you watch some exterior video a lot of the times they will lift the inner rear tire from the front being so soft and the rear being so much stiffer (in respect to roll balance) . This is really obvious on even stock performance trim cars like the Fiesta ST.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (06-13-2019) |
06-12-2019, 12:06 PM | #68 | |
Drives: 2017 86 860 Special Edition
Agree, having owned an EK in the past. Honda Tech's race forum is riddled with large rear hollow bars and over sprung rear rates. Not uncommon to see 12K front and 18K rear. Recently the front biased stagger is becoming the norm. A lot of Japanese tuners use this to get the car to rotate better to great effect. |
The Following User Says Thank You to RayRay88 For This Useful Post: | NoHaveMSG (06-12-2019) |
06-12-2019, 12:24 PM | #69 | |
Anti stance.
06-12-2019, 12:39 PM | #70 |
Drives: Crapcan
Yeah I have no doubt. Sway bar is not the whole story. I know there is a CRX over here that does hill climbs and pretty much runs no rear suspension. I know a bunch of drift guys out here run stupid stiff setups with no bars at all, but drifting so I am pretty sure that with my 6k/6k rates that my sways are not a huge part of my setup, just that them being adjustable allows me to change the behavior of the car a bit.
Similar Threads | ||||
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars | armyoffoo | Brakes, Suspension, Chassis | 10 | 08-08-2018 08:28 AM |
Oem sway bars | Marks Boosted | Brakes, Suspension, Chassis | 2 | 07-20-2017 07:29 PM |
WTB F&R sway bars | blkmamba | Canada Classifieds | 1 | 06-04-2017 02:15 PM |
FR-S stock sway bars compared to TRD bars | babydriver | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-01-2014 09:12 PM |
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
