04-06-2013, 01:19 AM | #57 |
Drives: Altezza RS200-Z 6MT
This is easily overcome with some decent aftermarket oil. Big thread on it here>> http://www.ft86club.com/forums/showthread.php?t=16604
If all else fails learn to double clutch. Half the problems come from guys who've driven FF for the last 10-20 years jumps in a FR & tries to change gears the same way. |
04-06-2013, 10:13 AM | #58 | |
Drives: FR-S 6MT
This is true.. Had the issue with my C6.. Got better after 12k miles or so.. But 2nd never liked to be rushed when cold.. Once warmed up.. All was fine...
Never did have the issue with my M3 though.. Quote:
04-06-2013, 11:15 AM | #59 |
Boosted
Drives: Sideways
Only our forum people would have access to talking to design team members and leads of the project and such.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
04-06-2013, 11:20 AM | #60 |
Drives: 2013 red FR-S, OFT. 2000 Miata SE
I have had both the Miata and the RX-8 with the 6 speed gearbox. I am hoping the FR-S gearbox is the same as the RX-8. It can easily handle 300whp. I have not noticed difficulty in shifting any of these cars, but I do not speed shift. Bob Bondurant said the key to winning a race is finishing. So he taught, be easy on your equipment. I do a technique called "Eggshell shifting". Two fingers of light force should be all you need to get any gearbox into gear. Letting the fingers act as a spring, so gentle force is applied to the shift lever. This also works great on the older Ferraris with those huge gates. After a 30,000 mile break in, I switch to Royal Purple. The syncros are not as effective with Royal Purple because it is so slick, and if you hard shift, it will grind the gears.
John |
04-06-2013, 11:35 AM | #61 |
Drives: MS3
The Mazdaspeed3 also suffers from this 2nd gear issue when cold....
04-06-2013, 01:50 PM | #62 | |
Drives: raven at
04-07-2013, 09:20 AM | #63 | |
Drives: Scion FR-S
04-07-2013, 12:00 PM | #65 | |
Drives: 1985 P-Type
Losing the needle means losing peripheral reference to speed. Instead of glancing at needle location you must look exactly at the value of a number. Difference between a watch with hands and a digital clock. Not everything needs to be digital. Consider, instead, that it would be easier to incorporate these readouts into the existing LCD. This would alleviate the "replacement cluster" indicator because you're just reprogramming the existing LCD display. Add sensors, let the driver cycle between readouts by pressing the turn signal stalk (or something like that), and set warnings as they wish. Then the driver can select which readout to monitor, and if they reach - for example - excessive oil temperature, then the LCD would automatically go to that readout and flash to indicate the problem. TRD could sell this as a full kit. Sensors, reprogramming (or aux control box), and something fun like a tachometer overlay that has yellow and orange markings and the TRD logo. |
04-07-2013, 12:29 PM | #66 | |
Drives: 2012 honda civic ex
04-07-2013, 01:24 PM | #67 | |
Drives: 2018 Golf R
Sent from my Nexus 4
Parting out HERE
04-11-2013, 11:21 PM | #68 | |
Drives: 1985 P-Type
If I knew how to program this sort of thing, I would make a box that interfaced with the LCD to monitor other things, perhaps even Valentine 1 alerts. |
04-11-2013, 11:37 PM | #69 |
Drives: RAVEN
Good try at a spin.
04-11-2013, 11:59 PM | #70 | |
Drives: RV-7
The Following 5 Users Say Thank You to torqdork For This Useful Post: | bestwheelbase (04-12-2013), civicdrivr (04-12-2013), Fly Guy (04-24-2013), ftc~brz (04-17-2013), Noli (04-05-2014) |
Similar Threads | ||||
New manual driver - SPEED BUMPS! | eifer | Engine, Exhaust, Transmission | 47 | 06-16-2015 01:27 PM |
FS: Toyota 86 GT! 6 Speed Manual ! Black ! [VIC] | os86 | Australia Classifieds | 0 | 12-19-2012 05:01 AM |
Whiteout 6 speed manual (Raleigh, NC) | low trq | Southeast | 3 | 10-29-2012 03:57 PM |
Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) -- General Topics | 35 | 06-24-2012 02:22 PM |
Another reason to buy a manual transmission car... | xantonin | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 08-10-2011 11:30 AM |
