Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
11-15-2017, 07:29 PM | #1 |
Brake light comes on sometimes when I brake
My brake fluid is low, maybe that’s why. My question is, can I just put some brake fluid in it and call it a day or do I have to remove the old brake fluid and put new one in it?
11-15-2017, 07:41 PM | #2 |
Drives: 17 86
Proper terminology and nomenclature is important.
You have three brake lights that should illuminate when depressing the brake pedal. Are two of them not working? Brake lights do not normally have brake fluid in them, that could be the cause of the intermittent illumination of one and the failure of the other two and could also explain the low level in the brake-fluid reservoir if your brake lines are indeed also hooked to the brake lights somehow. I'd add brake fluid to the reservoir just to make sure. No need to drain and bleed unless your brakes are mushy and the brake lights bubble when you get on the brakes. Brake fluid can be real hard on plastic, too, so keep an eye on the brake lights for leaks. |
11-15-2017, 07:53 PM | #3 |
If it's the emergency brake light coming on ....... I'd suggest you just add some brake fluid .....
humfrz |
11-15-2017, 08:09 PM | #4 |
Drives: 17 86
11-15-2017, 08:10 PM | #5 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Most usually brake fluid being on the low side means that it has migrated out to the calipers to make up for the brake pads being worn away.
May want to check on the pad thickness currently. Changing those and pushing the fluid out of the calipers would move the "lost" back into the reservoir. As long as you're farting around with it anyway, bleed in new fluid too.
"I gotta rock." -- Charley Brown |
The Following 4 Users Say Thank You to bcj For This Useful Post: |
11-15-2017, 09:06 PM | #6 |
For sure do not top it off without checking the pads first. If you top it off and then later find out the pads are gone, you will need to take fluid back out or else it will overflow and make a mess when you put the new pads on. As bcj says, it’s usually an indication of pads being worn. If the pads are good and it’s low then it’s getting lost somewhere else. Check around the brake pedal for fluid. If there is fluid there then it’s the master cylinder. Also check the inside of your rims for a mess because a leaky caliper will often drip onto the rims and get slung around.
11-15-2017, 09:11 PM | #7 | |
Oh, it is the e brake light. I took the car to the dealership for it’s 60k service on monday and in the paper I got it said the brakes were fine, but last time I took it to get an oil change it said this. I’ll add brake fluid and see if it helps, thanks everyone. |
11-15-2017, 09:18 PM | #8 |
Do NOT just add fluid. It went someplace. If your brake pads were down two visits ago they didn't magically regenerate this trip. They are worn to the point your fluid is low enough to trigger the warning light and adding fluid isn't going to fix the root cause. Take it back and have them actually look at the pads this time.
The Following User Says Thank You to Tcoat For This Useful Post: | winstonscifi (11-15-2017) |
11-15-2017, 09:18 PM | #9 | |
Wow, your fluid is low yet the dealership said your brakes were fine. I think it’s time to go to another dealer. |
11-15-2017, 09:59 PM | #10 |
Well, for sure your brake pads are getting down there.
Adding fluid might keep the light from coming on, but, it won't add to the pads. However, I doubt that they are now down below 4 mm from 7-8 mm, just 7,500 miles ago. Bubba says they are most likely good for another 5-10,000 miles. I reckon @Ultramaroon would recommend all new pads, rotors and calipers ..... he always goes first class. @Tcoat recommends new pads ...... because he's in the brake business and most likely gets some sort of kickback ....... somehow ....... it's a balance of trade thing. humfrz - senior master brake specialist - retired.......... |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (11-15-2017), winstonscifi (11-15-2017) |
11-15-2017, 10:15 PM | #11 |
Drives: 17 86
The light is telling you there is a fault with the brake system. Get an actual answer.
11-15-2017, 10:18 PM | #12 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Attached shows new and minimal specs for all brake linings. (From 2012 BRZ service manual, taken from this site).
The Following User Says Thank You to ToySub1946 For This Useful Post: | humfrz (11-15-2017) |
11-15-2017, 10:31 PM | #13 |
Terruko,
"My question is, can I just put some brake fluid in it and call it a day or do I have to remove the old brake fluid and put new one in it?" This is >poor advise< from me, but here it is. I'd throw caution to the wind. Add a minimal amount of new brake fluid to it's reservoir (like 1 to 1 1/2 ounces only), just enough to make that instrument cluster brake light stay off. You don't want to fill to the max level, as later, when new pads are needed level will then go up by itself. Being a former auto tech, I firmly believe in giving her only what she begs for. Never know, you might just decide tomorrow to trade her in. Attempting to read what the tech wrote...appears left front disc brake pad has 4mm remaining. Minimal would be 1.5mm as it's limit. So that one needs to be checked again, next service. Possibly a New Year's Resolution. Have a nice Holiday season. Last edited by ToySub1946; 11-15-2017 at 10:51 PM. |
11-15-2017, 11:04 PM | #14 | |
義理チョコ
I'll admit I'm a sucker for fresh rotors, though.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Cole (11-15-2017) |
Similar Threads | ||||
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video | continuecrushing | DIY (Do-It-Yourself) Guides | 44 | 11-23-2020 06:17 PM |
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) | BirdTRD | DIY (Do-It-Yourself) Guides | 17 | 11-06-2017 08:42 PM |
Valenti 4th brake light vs Valenti Style brake light? | JGalp | Electronics | Audio | NAV | Infotainment | 9 | 03-24-2016 05:48 PM |
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
