Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
09-08-2020, 10:22 AM | #1 |
Drives: 2017 Subaru BRZ
Transmission Fluid Recommendations
I have a boosted brz and very rare cases I can't shift to any gears from a stop. I was looking to do an tranny fluid change and see if that works. What would you guys recommend?
Thanks Sent from my SM-G960W using Tapatalk |
The Following User Says Thank You to j_ros94 For This Useful Post: | humfrz (09-08-2020) |
09-08-2020, 11:36 AM | #2 | |
I'd suggest you first check the fluid level. If you're bound and determined to change brands of oil, a quick forum search would yield all kinds of peoples choices. If it were me, for average driving, I'd stick with the OEM stuff. |
09-10-2020, 05:44 PM | #3 |
The Dictater
Drives: '13 Red Scion FRS
Did you try bleeding/adjusting the clutch yet? I would try that before looking at transmission oil.
The Following User Says Thank You to Spuds For This Useful Post: | solidsnake11 (09-18-2020) |
09-10-2020, 05:58 PM | #4 |
Drives: '13 Whiteout
Motul however you need to see what the problem is
09-18-2020, 03:52 AM | #5 |
Drives: '16 BRZ
Aside from Motul, Redline is a good choice.
09-18-2020, 11:40 AM | #6 |
Purist
Drives: 2013 FRS - Hot Lava
Pentosin MTF2
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
10-03-2020, 03:54 PM | #7 |
Drives: Toyota Gt86 2012
seeking for help
Hello everyone! I m new here. I would really appreciate to know how to change atf in my 2014 gt86 as I m looking forward to changing it. Would really appreciate an in depth procedure. Tia😊
10-03-2020, 04:47 PM | #8 | |
義理チョコ
TX6A AUTOMATIC TRANSMISSION / TRANSAXLE: AUTOMATIC TRANSMISSION FLUID: REPLACEMENT; 2014 MY FR-S [07/2013 - ] Not my site. See more in signature line.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (10-04-2020) |
10-04-2020, 03:04 AM | #9 | |
10-04-2020, 02:47 PM | #10 |
義理チョコ
I mean no insult. If you are unable to find the drain plug, it's probably best that you have a professional do the job for you.
10-04-2020, 03:34 PM | #11 |
The Dictater
So out of curiosity, it looks like *2 in the first image is the overflow plug, is there a separate drain plug on the pan somewhere? I have an MT, otherwise I'd look next time I'm under there.
10-04-2020, 04:12 PM | #12 | |
義理チョコ
DIY: Automatic Transmission Fluid Change
10-05-2020, 12:45 AM | #13 |
Drives: 2017 subaru brz
Out of curiosity, since almost no one changes the transmission fluid with OEM fluid (according to the forums), and Subaru OEM Gear Oil is GL5 while the transmission recommends GL3/4, does that mean Subaru themselves do not make an OEM fluid suitable for our transmissions?
I really enjoy the oem shift feel but really can't make a decision if I want to buy their High Performance Gear Oil after reading too many forum posts that it will deteriorate my transmission because of the GL5 spec. Please enlighten me lol. I wonder what was put in from the factory.. |
10-05-2020, 10:10 AM | #14 |
Purist
Similar Threads | ||||
transmission fluid | John27 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 04-25-2017 08:14 PM |
Transmission Fluid | euthqt | Issues | Warranty | Recalls / TSB | 8 | 04-14-2016 08:20 AM |
6MT Transmission Fluid Recommendations | Ferrari | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 97 | 04-30-2015 05:06 AM |
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. | B-R-Z | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 07-03-2014 08:06 PM |
What transmission fluid are you using? | Chillz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 04-06-2013 10:45 PM |
