Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 10-21-2015, 03:41 PM   #1
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Wish list
This should be interesting...
Let's assume You had R100,000 to spend on aftermarket bits what would you buy? (About $7400 or so at today's exchange rates).
In no particular order here are some of things I'd love;
Exhaust (headers first, then the rest)
Edelbrock SC
Brakes (maybe just rotors etc, maybe bbk)
Wheels (plenty nice 18" ones out there) + tyres of course.
Front splitter - looks ace
Valenti tail lights (already have these)
Carbon fiber drive shaft
Pulley kit (eg Perrin)
Oil cooler
Problem is this wish list is way more than my imaginary budget ;-)
86 South Africa is offline   Reply With Quote
The Following User Says Thank You to 86 South Africa For This Useful Post:
Dammod (10-22-2015)
Old 10-21-2015, 03:42 PM   #2
Apex Strider
Apex Strider's Avatar
Drives: Toyota 86
That V8 with Hybusa heads from NZ.
Sent from my GT-I9300 using Tapatalk
Apex Strider is offline   Reply With Quote
Old 10-21-2015, 03:56 PM   #3
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Tyres and brake pads, 9 sets of each
Fish Eagle is offline   Reply With Quote
The Following 3 Users Say Thank You to Fish Eagle For This Useful Post:
Alang (10-22-2015), Chrisgalactic (10-23-2015), JouMaSeHoes (10-22-2015)
Old 10-22-2015, 07:25 AM   #4
Dammod
Dammod's Avatar
Drives: .
Lol I'll just copy and paste mind from Excel already written up:
Phoenix Performance AVO Bolt On Turbo Kit with Ceramic Coating, Billet Turbocharger & 8 PSI Actuator
AVO 3.0" Stainless Steel Full Turbo Back Exhaust System (Turbo Setup) - No Cat
AVO Turbo Kit Blow Off Valve - Polished
Omni 3Bar Map sensor
AVO Sports Filter Kit with Airbox Kit (Turbo Setup)
AVO Breather Tank for the Turbo Setups
Denso 265lp/hr Bolt-In Fuel Pump with New Cage
AVO Modified Bosch 1000CC Bolt-In Port Injectors with Plug & Play Loom
Heavy Duty Pressure Plate with Dampened Cushion Organic Disc
Rear Differential Anti-Tramp Bushes
Gearbox Crossmember Bush
Rear Diff Member Bushes
Innovate EBC
Powerbrake RS Series High-Carbon slotted discs
Ferodo DS Performance brake pads
BC Coilovers
More then 100k but its a wishlist!!
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 10-22-2015, 09:54 AM   #5
jcz
Drives: waiting for BRZ
Get Ferodo DS2500 instead of DS Performance. They are ok for spirited driving at least and fine for daily driving too.
jcz is offline   Reply With Quote
The Following User Says Thank You to jcz For This Useful Post:
Dammod (10-22-2015)
Old 10-22-2015, 10:11 AM   #6
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
2 jz swop
GeeTee86 is offline   Reply With Quote
The Following 3 Users Say Thank You to GeeTee86 For This Useful Post:
Apex Strider (10-22-2015), Chrisgalactic (10-23-2015), Fish Eagle (10-22-2015)
Old 10-22-2015, 10:48 AM   #7
86 South Africa
Nice list... but you have not helped me narrow down some options - I think you've just added to my wishlist haha.
Dammod (10-22-2015)
Old 10-22-2015, 10:50 AM   #8
86 South Africa
Hahaha - I don't have as much time on my hands to smoke tyres on the track (yet!).
Old 10-22-2015, 11:44 AM   #9
Fish Eagle
Platinum Member
Fish Eagle's Avatar
On a more serious note, in answer to your question, this is what I'd do...
But I'm a wrinkly, so... whatever
More torque. Not bhp, just torque to get rid of the mid-range RPM slump.
Either a good header and tune, or add ethanol and dual mapping, or a low boost SC.
Many people know a lot more about this than me, but the need is a bit more torque.
I went the SC route.
More tyres. The stock tyres just don't cut the cake.
Well, unless you like making a lot of smoke and noise without going very fast, then enjoy.
If you wanna go fast, get some real tyres.
That probably means some nicer and wider wheels too. Yep, good plan, and they look cool too.
But don't go beyond 17'' unless you like paying a kakhuis full of money for tyres.
Fit crash bolts to get some negative camber up front. (approx -1.5°)
They cost about R100 and will save you a fortune in tyres if you drive enthusiastically.
Change your brake fluid. If you drive with gusto, the stock fluid can kill you.
Dump it, and replace with something like Motul RBF660. Costs about R400 + labour.
Do track days, ideally at a safe track like Red Star or Midvaal, and learn your car's handling at the limit.
Then, unless you've gone the SC route, take your (substantial) change from your R100k, and have a good p*ss-up with your mates and congratulate yourself for having such a cool car for so little money and for being so kleva!!
The Following 2 Users Say Thank You to Fish Eagle For This Useful Post:
86 South Africa (10-22-2015), JouMaSeHoes (10-23-2015)
Old 10-22-2015, 12:00 PM   #10
riri86
riri86's Avatar
Drives: 86 High Manual
Rocket Bunny Version 1!!!
2014 High 86 Manual
riri86 is offline   Reply With Quote
Old 10-22-2015, 12:02 PM   #11
86 South Africa
Smile
Considering starting with some brake upgrades, an exhaust and tune.
Then I'll see if I need anything else... tyres and wheels possibly next after that.
Track days are great, but time is an issue at the moment - I also don't like Z generally because they only like going right. Red star doesn't do car days often!
Is Midvaal still so damn bumpy?!
Old 10-22-2015, 01:09 PM   #12
Fish Eagle
Platinum Member
Fish Eagle's Avatar
The Z is a dangerous track especially when you mix it with the arrogant M3 brigade on Supertrax days - yeech.
If you go there with an N/A 86, then run in class B - much better.
I have to run class A and it's not fun.
Red Star normally has car days on Wednesdays twice a month, and sometimes there are charity or car club days that you can get into. Give Youlanda a call at RSR and ask her to put you on their SMS notification list. Also, subscribe to Red Star's Facebook page for updates. It's a wonderful, technical, and very safe track for cars.
And yeah, of course Midvaal's still bumpy, but it's a lot better than it was a few years ago. At least there are no potholes like there used to be
I love Midvaal because I enjoy mixing it with the racecars which grows one's experience and skills in leaps and bounds. Still my favourite track.
Here's what Midvaal looks like now (August). Ignore the oil and cement mess. It's very abnormal to have 3 racecars (a Porsche 928, VW Fox and a Supra) empty their sumps on the track in one day - phew! They used 16 pockets of cement to get the track sort of working again...
[ame="https://www.youtube.com/watch?v=uKtO4M0OdW0"]Midvaal Raceway Toyota 86 2015-08-15 1m19.3 - YouTube[/ame]
Old 10-22-2015, 03:13 PM   #13
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
I'm sure a v1 rocket bunny kit wouldn't cost around R100k after installed ?
It seen kits (I'm assuming these are replicas) on eBay for under $2000
Would be cool to see companies like RACE! Build a few turbo Rocket bunny 86's in SA
FT_86_SM_GP is offline   Reply With Quote
Old 10-23-2015, 12:08 AM   #14
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
1)Cayman GT4
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
The Following User Says Thank You to sav For This Useful Post:
Brz To Do List! SkyBRZ Member's Car Journals 1 02-10-2015 05:09 AM
H.P.D.E Day List Imperius Tracking / Autocross / HPDE / Drifting 8 04-25-2014 12:20 PM
LED List For BRZ/FR-S/GT-86 jjkerr626 Cosmetic Modification (Interior/Exterior/Lighting) 26 07-12-2013 04:43 PM
Mod list before car, anyone else? Shadowsong6 Scion FR-S / Toyota 86 GT86 General Forum 13 03-01-2013 08:53 AM
TSB list? DarrenDriven Issues | Warranty | Recalls / TSB 15 11-03-2012 07:38 PM
